Old September 30, 2009, 10:08 PM
Default Laptop problem
Well, it's been a long time coming but my monitor is literally falling off of it's hinges. One side is cracking, and the one side literally came apart tonight. Duct tape slowed this process but it only was temporary. Is there any way to re-attach a monitor? Getting to look inside now it looks like the metal broke from just opening and closing it, and the plastic around it broke from the pressure. Really it looks like I might just be better off finding a way to hold it in place and forget about ever opening and closing it again. Just use it as a desktop more or less.
I'd really rather not buy another laptop, but I suppose one of those $200 netbooks could suffice for the time being.
Any suggestions?
Old September 30, 2009, 10:13 PM
Any suggestions?
Once the hinges break on a laptop generally the only way to fix it is to replace the casing whether it be the screen portion, the bottom or both.
Old October 1, 2009, 07:43 AM
Any guess how much that is? I'm thinkng it's not worth it
Old October 1, 2009, 08:11 AM
gingerbee's Avatar
cheaper to buy anew laptop most of the time ( don't quote me on that i said most of the time ha ha )
Old October 1, 2009, 08:42 AM
3.0charlie's Avatar
Same thing happened on my Dell lappy; cost me 20$ on ebay for new hinges and 35$ for a new screen cover. Looks and handles like a new one now.
Hydro-Quebec is salivating...
Old October 1, 2009, 10:15 AM
Thund3rball's Avatar
^^ Here here. This is HWC! What kind of laptop you got JMCD?
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old October 1, 2009, 12:05 PM
Ugh, it's some kind of MDG. No idea what model. It's about 2 years old.
Model MS1613 and some chineese stuff on the back.
I don't think this is fixable though as the hinge is still in, but it's broken off of the monitor. I'd need a replacement monitor I believe.
Old October 1, 2009, 12:44 PM
Seems MDG notebooks are often just rebranded from Acer or MSI. Anychance yours is a an Acer Travelmate 613 or something along those lines in an MSI model number?
Desktop:
See the drop down!
HEATWARE
Old October 1, 2009, 03:46 PM
3.0charlie's Avatar
Nope, no need to replace the monitor, only the frame.
MAC DDR laptop mem in an Intel based laptop? sswilson RAM 6 June 2, 2009 12:30 PM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
Laptop / Laptop build T.t74)Rocky New Builds 0 November 8, 2008 08:29 AM
Laptop Phobia Mobile Computing 7 September 8, 2008 01:53 PM
New laptop.. omgwtf Mobile Computing 11 January 31, 2008 06:07 PM
