  #41 (permalink)
Old June 25, 2009, 01:19 PM
sswilson's Avatar
Originally Posted by lowfat View Post
right click the file, get info. then 'open with'
EDIT: 10 seconds to slow.
Right click?
The macbooks I was playing with only had one mouse button. Do the new ones have two?
  #42 (permalink)
Old June 25, 2009, 01:23 PM
lowfat's Avatar
Originally Posted by sswilson View Post
Right click?
Two finger tap = right click.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #43 (permalink)
Old June 25, 2009, 01:26 PM
MacJunky's Avatar
You just have to tap it with two fingers to right click. Optionally you can hold down the control button and then single click to make a right click.
*Edit
This time lowfat ninjad me :P
*Edit
see here:
Enable Right Click on Mac Book Pro or Powerbook
That page has an image of the Trackpad tab in the Keyboard & Mouse prefpane
  #44 (permalink)
Old June 25, 2009, 01:33 PM
SneakySnake's Avatar
Download iStat menus, its a performance monitor that'll sit in the top bar. Measures temps, network stuff, CPU, etc.
i5 8400 || Strix 1080 Ti || 16 GB DDR4 3000Mhz
  #45 (permalink)
Old June 25, 2009, 01:38 PM
Thund3rball's Avatar
Right click?
By a new mouse. I never liked Mac mice and have always tried to use something else on any Macs I've worked on. Right click works fine.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
  #46 (permalink)
Old June 25, 2009, 05:16 PM
lcdguy's Avatar
well i managed to hook my laptop up to my 30" lcd and it looks awesome. I have one question. I am synching my ipod right now and the temp seems high. How high is too high and does it have a thermal cutoff threshold.
  #47 (permalink)
Old June 25, 2009, 05:59 PM
Download iStat Menus, it'll tell you all of the temps.
As for how high is to high, for a laptop I'd say getting into the 70's isn't uncommon under load, so probably 80's is getting a bit to high. I'm pretty sure that the chips are rated for around 100 tops though
Also there is the smcFanControl app which lets you adjust fan speeds if you think your temps are getting a bit high
  #48 (permalink)
Old June 25, 2009, 06:01 PM
sswilson's Avatar
It wasn't a mouse. It was the single mouse button on the laptop itself.
  #49 (permalink)
Old June 26, 2009, 03:47 PM
lcdguy's Avatar
a little bit of an update in my foray's into the "other side". I found an awesome little tool for burning cd/dvd's called burn. it works well, has a simple to use interface and is small (31 MB)
  #50 (permalink)
Old June 26, 2009, 04:45 PM
I just have to put in my two cents here. While I respect the MacBook for being a good solid laptop, I have trouble paying so much extra for design premium when I can get a better speced laptop that still looks and preforms great from another manufacturer. That said, I hope your transition goes well!
Antec 900
Intel Core i5 @ 2.66GHz
Asus P7P55D motherboard
EVGA 9800 GTX+ Superclocked
4GB of Patriot Viper II DDR3 RAM
2X320 GB Western Digital @ 7200 RPM
Plextor DVD +/- RW
Corsair TX 750 W power supply
Windows 7-64
Hrm. Something just crossed my mind Sagath Power Supplies 3 March 20, 2009 07:52 PM
