Old February 28, 2009, 12:28 PM
Default Salvaging a Broken Laptop
so my laptops busted, screens destroyed, and some panels have come out.
Laptop is a Dell Inspiron 1501
The laptop was smashed, it was on when it was smashed and it immediately turned off after it was smashed. Tried turning it on but then I saw some smoke rise as I tried to turn it on.
Visible Trauma:
-Screen is cracked very badly, looks like spiderwebs on the screen.
- Panel where the power button has fallen off
Do you guys think it would be possible to just remove the screen completely and use it like a desktop? Only problem is, it wont turn on...
I think I may just salvage the battery, HDD and Ram. I think I can salvage the CPU but not the GPU.
Any advice guys? I'm sure someones had a broken laptop before
Doubt the warranty is any good. Bought the thing October 2007.
CPU: E5200 @3.5ghz 1.232v [12.5*280](stock hsf)
MOBO: Biostar TP43D2-A7
VID: Diamond HD4870
HDD: Seagate Barracuda 7200.10 500gb
RAM: G.Skill 4GB @ 576mhz (4.4.4.12)
PSU: Seasonic SS-400ET
Old February 28, 2009, 12:55 PM
arekieh's Avatar
sounds pretty bad
take it out of the casing and see if theres any damage to the internal components.
Try to piece of back together, if u have another laptop or know somebody that does, try to test each component to see if everything works
Old February 28, 2009, 01:40 PM
lol, so I called dell. they said it would cost $400 to repair the laptop, I sorta laughed and then said thx for your time lol. I think I paid $400 for this laptop when I bought it a year and 5 months ago.
Just opened the thing, lots of components, some I can't recognize. Wonder if I can salvage the wifi. I seriously want to salvage the diskdrive, since the one in my rig kinda blows.
Wish I could salvage the card reader cuz it looks pretty neat lol. Gonna take off the heat sink now wish me luck guys!.
Also, the HSF looks like it has a loong peice of copper. Might beable to sell it, copper is expensive right?
I've gota show you guys some pics of this stuff, it just looks so neat! lol
VID: Diamond HD4870
Old February 28, 2009, 01:58 PM
is it possible to make an HTPC with a laptop CPU? I've pretty much got most of the components I would need.
VID: Diamond HD4870
Old February 28, 2009, 02:15 PM
Phobia's Avatar
What are the specs of the cpu, etc?
edit: I was wrong
Old February 28, 2009, 02:36 PM
arekieh's Avatar
id like to see some pics too. Never seen the innards of a laptop
Mobo: Asus P6T Deluxe | CPU: i7 940 | Ram: 3x2 GB | HSF: CM V8 | GPU: HD 6950 | PSU: PCP&C 750W | ]HDD: WD 500gb x3, 120GB Vertex 2 | Case: Antec 1200 | Monitor: 3x Asus VE247H | OS: Win7 Ultimate x64
My Trading Rep:
HWC
OCN
Heat
Ebay
Old February 28, 2009, 03:32 PM
Iamcanadian7's Avatar
No, it's not, laptop cpus are still the pin style and are specific to laptop boards. Only high end systems that use desktop processors use a 775 retention system.
By the sounds of it the system is junk spare the HDD, ram, cpu, optical drive if its removable. I'd take it to a place that specializes in laptop repairs, Dell quotes you when they haven't seen the system and it could be an easy fix, though by the sounds of it, it's too fargone to fix before you would be into ew system territory.
Pics would help if you can, if the body of the system is easily fixed then you can just hook up an external monitor.
Old February 28, 2009, 11:22 PM
heres some pics
The inside of my computer
The two chips to the right of the fan are the CPU and GPU
my smashed screen
My HSF
hdd
WLan chip
there was also a modem chip thing, but the pic didn't turn out well
Update: I put the peices back together, I realised that the computer wasn't turning on because the cable connecting the screen to the mobo had popped out.
I duno if this is bad or good, but I basically just popped the HSF back ontop of the CPU, my cpu wont over heat will it? The gpu just had some weird foam paper between gpu and HSF lol.
Anyways, with everything back together I tried to turn on the comp and it did actually boot. Everything sounded normal, but of course I couldn't verify anything, since I had no screen. I tried connecting the laptop to an external monitor, but the external monitor didn't detect anything...
I might try again, with a diff monitor
VID: Diamond HD4870
Old February 28, 2009, 11:39 PM
arekieh's Avatar
that screen looks terrible howd it get smashed?
My Trading Rep:
HWC
OCN
Heat
Ebay
Old February 28, 2009, 11:46 PM
only useful thing out of a smashed laptop is POSSIBLY the hdd if it didn't get damaged.
Otherwise they are junk.
LG drive broken? Cadence Storage 7 June 6, 2009 02:13 PM
what do you do if your car is broken into? CTA Off Topic 31 March 1, 2009 12:17 PM
My dog is broken Phobia Off Topic 11 January 21, 2009 12:47 AM
repair some broken hardwares CTA Off Topic 18 October 14, 2008 08:27 AM
