-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   Need Laptop advice (http://www.hardwarecanucks.com/forum/mobile-computing/13935-need-laptop-advice.html)
Ghlin January 18, 2009 07:15 AM
Need Laptop advice
Normally this wouldn't be an issue for me, but someone is looking for a business laptop and needs some specific such as
- Has to be XP, no vista
-Laptop needs to come with a numpad instead of just the top row.
Thanks
geokilla January 18, 2009 01:35 PM
Buy a good, bang for buck laptop. Reformat using Windows XP. Install what you need. Done.
As for the laptop, ASUS M51SN-X1 or C1 or something of the M51SN series will do. Note that you'd pay at least $900.
Chilly January 18, 2009 11:38 PM
Budget? That would be a big help. :haha:
3 of 7 January 18, 2009 11:52 PM
Vostro 1700
Dell Vostro 1710 Laptop Details
I have one and I love it, I was succesfull at installing XP on it before Vista SP1 came out ( back on Vista now)
lcdguy January 19, 2009 09:35 AM
look at the vostro's. Incase you can only get it configured with vista make sure to get the xp recovery dvd. Dell has a horrible reputation for provided XP drivers as of late.
3 of 7 January 19, 2009 10:31 AM
According to their site you can get it with XP Pro installed..... For 90 bux extra that is....
mklym January 19, 2009 10:36 AM
Thanks
Are you looking at buying new or used. New laptops with XP are getting rare. Besides Dell offering laptops with downgrade rights, Lenovo/IBM offers some models with XP Pro, and I believe HP does, as well.
There are lots of deals to be had on used laptops. Check some of the notebook specific forums buy/sell sections.
As for the number pad is concerned, you are looking at a laptop with a 17" display. I do not recall any units with smaller screens that have a dedicated number pad. Targus makes a USB number pad. It can be used with any computer.
With more info, we might be able to give better suggestions.
Babrbarossa January 19, 2009 10:57 AM
I've found that the lenovos are pretty bomb-proof. Very stable and can stand a beating.
lcdguy January 19, 2009 01:41 PM
i can confirm this as most of my problems at work with the laptops are the dell's the ibm's very rarely have issues and when they do it's a big like a mobo dieing. Just buy the accidental damage protection and you never have to worry until the warranty runs out.
rjbarker January 20, 2009 04:41 PM
This is the one I got my son about 6 months ago.....its a friggin Rocket for a Laptop.
Games like a banshee!!!
ASUS M50SV-A1CORE 2 Duo T9300 15.4IN WXGA+ 3GB 250GB GeForce 9500M GS 512M Vista Premium Notebook - DirectCanada
PS He didn't want the 17 inch monitor...to big n bulky this one is 15.5"
