Old October 1, 2008, 02:12 PM
Level up: 29% Level up: 29% Level up: 29%
Level: 11 - 241 points to level up
Default locked hdd
hello,i have a acer laptop here from a customer,kids went into bios and set a password,cant boot to vista now,keeps asking for hdd password and after 3 tries reboot,been messing with it for over a week,, its in pieces now lol...is my only option,new hdd and hope laptop dont lock it to?
thanks
HTPC Case: Antec Fusion Mobo: Abit AN-M2HD Cpu:5200+ Windsor@2600mhz Ram: Ballistix Tracer PC2-6400 2x1 gb Hdd: 500 gig WD PSU: 430 watt Speakers: Logitech - Z-5500 Display:
Samsung 40"
Computers have lot's of memory but no imagination
heatware
Old October 1, 2008, 02:35 PM
SugarJ's Avatar
Level up: 38% Level up: 38% Level up: 38%
Level: 14 - 363 points to level up
No clear_cmos jumper?
Intel E8400 Biostar Tpower I45 Diamond HD4870 512mb G-Skill DDR2-1000 4GB Creative Xtreme Audio PC P&C 750W Quad Silencer Antec 900 Logitech G-15, G-5
WC Loop: Swiftech Apogee GTZ Danger Den CPX-Pro, Maze 4 GPU Black Ice GT Stealth 240 Rad
Old October 1, 2008, 02:46 PM
clear_cmos did not work hdd still locked,
Samsung 40"
heatware
Old October 1, 2008, 02:50 PM
SugarJ's Avatar
That sucks. Can you access the drive in another machine? They're usually SATA drives.....
Also, did you remove the battery while clearing cmos? Can you boot to a USB key or DVD? You could probably flash a new BIOS, which should erase the lock if it is BIOS based..
Old October 1, 2008, 02:53 PM
c&p from another forum
the password is stored on the hdd circuit (similar to an eprom)
forget about removing it yourself. unless the data is worth it, it will be chaeper just to buy another drive.
have not tried it in another pc yet.worth a shot
Samsung 40"
heatware
Old October 1, 2008, 02:59 PM
SugarJ's Avatar
Ouch. Unless you can access it from another machine (not likely), it's new HDD time.
Old October 1, 2008, 03:00 PM
found these guys @ $85us Nortek - ThinkPad Password Solutions: Power On, Supervisor, Hard Disk Password Removal
i think new hdd might be the way to go,orig. hdd has no data worth any value
edit: If you have a password protected unit that is not manufactured by IBM and you require our services, we request the entire system (including A/C adapter) is shipped to us for a No-Charge evaluation. Once the unit is evaluated, we will forward password removal options and pricing details.
more than 85 omg,lol
Samsung 40"
heatware
Old October 1, 2008, 03:10 PM
SugarJ's Avatar
New HDD, I picked one up from NCIX for my son's acer for about $60....
Old October 1, 2008, 03:18 PM
hopefully there will be one onsale, new deals start tonight :)
Samsung 40"
heatware
Old October 1, 2008, 06:19 PM
sswilson's Avatar
Super Moderator
As long as you have the backup disks, and there's nothing on the laptop that's needed, I can't imagine it'd be less expensive to go the password removal route.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Forum Jump
