-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   Asus EEE 1000 battery life (http://www.hardwarecanucks.com/forum/mobile-computing/10208-asus-eee-1000-battery-life.html)
muse108dc September 19, 2008 09:50 PM
Can anyone tell me what the actual battery life under load and idle of the EEE 1000
cyclo September 20, 2008 08:49 AM
For the Eee PC 1000H under normal use (surfing, emailing, IM) between 4 to 5 hours. Not sure about idle as I have mine programmed to go to standby after 20 minutes.
metacore November 13, 2008 12:01 PM
i get about 5 hrs or surfing, taking notes, etc. with brightness at level 3. this is with vista though -> supposedly has better power management, though i dont notice a huge difference from winxp
with everything turned down (wifi off, bt off, etc) i can get about 7 hrs of battery life.
CactusJoe December 18, 2008 06:51 PM
with the casual msn, downloading, surfer etc and very light gaming my battery goes for 5-6 hours when on power saving mode. Maybe its because it is really new. The predetermined timing arnt right most of the time, they even twich. One time, it told me my battery was critical but it still worked for one and an half hour.
5-6hours is ur answer ;P
