  #71 (permalink)
Old October 24, 2008, 01:03 PM
Dead Things's Avatar
Nope - no modding of the "lip" whatsoever. The screws are pretty much right up against it, but it works out so that the screws come out perfectly straight from the fan mount holes.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
  #72 (permalink)
Old October 24, 2008, 01:25 PM
Originally Posted by Dashock View Post
Hmm i would have to agree with SSwilson the first pic makes it look like the two left screws are flushed against that back fin? and how did you manage to put this black plastic on the back of your case as mine only has metal ?
Yup - the screws are flush against the fin, but I did not have to cut any part of the fin or lip away. Perfect fit.
I painted my case flat black. So that's not plastic you're looking at, but paint. It is the original revision - RC-1100-KKN1. You can look at my complete mod/build log here: NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection.
  #73 (permalink)
Old October 25, 2008, 06:33 AM
thanks. Very detailed.
