  #61 (permalink)
Old August 31, 2008, 10:56 AM
Dashock's Avatar
Level up: 4% Level up: 4% Level up: 4%
Level: 17 - 764 points to level up
lol great minds think alike i guess tell me how much it drops yer temps:p welll off to work to pay for my hobbies.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #62 (permalink)
Old September 2, 2008, 10:14 AM
=v4v=radsbee's Avatar
Level up: 25% Level up: 25% Level up: 25%
Level: 7 - 104 points to level up
That is a very nice looking case would look at it for a new build, love the space, Have a thermaltake armour now. Nice review.
Rads
Asus striker extreme
core 2 quad Q600 2.4ghz
4 Gb OCZ gold
500gb, 2 x160gb
BFG 8800gts 320
Silverstone Zues 750W psu
22" wide LCD
Logitech 5300 surround
supreme fx audio
Zalman 5.1 surround headphones
Zboard USB gaming keyboard
Razor Copperhead gaming mouse
xp pro
  #63 (permalink)
Old September 2, 2008, 02:10 PM
Dashock's Avatar
Thanx buddy i think after mine and cryostage review of this case there was a couple of members who went out and bought this case, i tried to keep it as unbiased as i could cheers!
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #64 (permalink)
Old September 5, 2008, 03:37 PM
cryostage's Avatar
Hey Das I just received from CoolerMaster the HAF 932 LOL
  #65 (permalink)
Old September 5, 2008, 08:42 PM
Dashock's Avatar
Hey when you gonna send me some stuff so i can review ?? eh lol And Btw i will be doing one more slight add on to this review i have been asked lately about my original thought of adding a Radbox to the back so im gonna take some shots of the problems areas in the back of the case so give me a few days to get everything set up.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #66 (permalink)
Old October 14, 2008, 08:54 PM
Dead Things's Avatar
Level up: 44% Level up: 44% Level up: 44%
Level: 8 - 101 points to level up
I just finished a w/c Cosmos S build with a PA 120.3 in the roof and a MCR220 off the back. If you like, I can take some pics of what I did to hang the rad off the back to give you some ideas...
Lemme know.
  #67 (permalink)
Old October 22, 2008, 04:43 PM
Dashock's Avatar
Would love it Dead but for my current build the triple rad is more then overkill for me anyways. For my next Intel i will definetely be modding the back so yes i would love to see some pics cheers.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #68 (permalink)
Old October 24, 2008, 01:31 PM
I used 2 inch screws as the spacers (came with the Swiftech radbox, which I used elsewhere). The pics are horrible, I know, so here's a quick explanation: Screws went into the fan holes with the heads inside the case. The screws were secured with nuts flush to the exterior of the case. The MCR220 has four fans in push/pull, so it was aligned such that the insides of the push fans were flush with the case cover that prevents use of a Swiftech radbox (hopefully you can see this in the pics). For the side of the rad not impacted by the case cover, another two nuts were used to align the rad straight. Finally, four nuts were used on the opposite sides of the push fans (as per the pics) to hold it in place.
No modding of the case cover required, and the rad is held securely in place. This is a pretty lousy explanation and some pretty lousy pics, but hopefully it makes sense. If you have any questions, please feel free to post back to this thread with them, or PM me.
Cheers!
View from the top. Tubes had to go this way because use of a PA120.3 on the interior roof of the case blocked the pre-drilled tubing holes. This is the best view of the nut-fan-nut configuration holding the rad in place.
View from the side. Here you can see the nuts on the exterior of the case keeping the screws straight. Also a bit of a better idea of how the screws were used as spacers.
The Farm...
Suite100: Q6600 @ 3.0 and 2 x 8800GTS 512 // FIREball2: Q6600 @ 3.4 and 9800GX2, 8800GTS 512 // Phenom: X4 9550 @ 2.64 and 2 x 8800GT, 8600GT // Sentimental: E1200 @ 1.6 and 2 x 8800GS // OldSchoolSLI: X2 5000+ BE @ 3.2 and 9800GT // Giga88: E6600 @ 3.4 and 8800GT // MissionServ: E6420 @ 2.8 // Core2Nix: E2180 @ 3.0 // ATI-eXPerience: P4 2.26 @ 2.9 and HD2600 Pro // 5FDserver: X2 4600+ @ 2.4 and 8800GS
  #69 (permalink)
Old October 24, 2008, 01:35 PM
sswilson's Avatar
Super Moderator
You didn't need to cut away any of the back "lip" for the screws? I'll have to get at the back of mine to see if the screwholes would be flush with the lip, or if perhaps they've modified it. (The screws must be tight against the lip if not).
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
  #70 (permalink)
Old October 24, 2008, 02:03 PM
Dashock's Avatar
Hmm i would have to agree with SSwilson the first pic makes it look like the two left screws are flushed against that back fin? and how did you manage to put this black plastic on the back of your case as mine only has metal ?
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Forum Jump
