  #31 (permalink)
Old July 10, 2008, 07:19 AM
sswilson's Avatar
Super Moderator
Originally Posted by Dashock View Post
things i lack unfortunely patience! lol im trying to ask Biff how he managed to route the 4 pin hole on the top left of my motherboard, i think with yer board for example you have a 6 pin connector and the case came with an extention as mine did.
Are you talking about the cpu connector on the motherboard (either 4 pin or 8 pin)?
That was my only real disapointment with cable management... I found I couldn't route it behind the motherboard tray and ended up running it up top tucked in behind the rad.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
  #32 (permalink)
Old July 10, 2008, 07:34 AM
Dashock's Avatar
Level up: 4% Level up: 4% Level up: 4%
Level: 17 - 764 points to level up
yep yu got it SSWilson the 4 pin connector to the motherboard BIFF on the other hand has managed to connect it and hes using the same powersupply so im asking him how he did it maybe he predrilled holes or something maybe an extension?
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #33 (permalink)
Old July 10, 2008, 07:53 AM
Level up: 21% Level up: 21% Level up: 21%
Level: 7 - 110 points to level up
sswilson is correct,the only way to run that 4/8 pin connector is behind the rad without modding the tray
Motherboard: Intel DX48BT (BoneTrail)
Motherboard BIOS: 1554
CPU: Intel QX6700 (Lapped)
CPU Overclock Speed: 3.8ghz
CPU Cooling: WaterCooled /Apogee GT/Custom Loop
CPU Idle Temp: 42 c
CPU Load Temp: 64 c
Memory: Kingston HyperX DDR3
Memory Speed: 1800mhz
Video Card(s): Foxconn 9800GTX
Video Card Speed: Stock
Sound Card:
PSU: PC POWER & COOLING Turbo Cool 1kw
Case: Cosmos S
  #34 (permalink)
Old July 14, 2008, 08:26 AM
Dashock's Avatar
I am looking at Biff's rigg hes modded his tray to be able to fit it and it looks reallly clean.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #35 (permalink)
Old August 6, 2008, 03:20 PM
Looking great. I noticed that you still have the white mobo standoff screw marking paper behind your mobo. I don't know if this is intentional, but imo if should be taken out. Here's an image of my cosmos that has been slightly modded and WC'd. Head over to OCF for the scoop.
  #36 (permalink)
Old August 7, 2008, 12:22 PM
magictorch's Avatar
Level up: 13% Level up: 13% Level up: 13%
Level: 18 - 773 points to level up
Very nice
Cable management isnt that easy-especially if you keep changing your stuff
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
  #37 (permalink)
Old August 8, 2008, 05:20 PM
cryostage's Avatar
Hey Dash ill have some photos for u on my install with Thermochill PA120.3 LOL and 2 pumps
  #38 (permalink)
Old August 8, 2008, 09:51 PM
Dashock's Avatar
Cant wait bro cant wait i think ill eventually put a thermochill in there once i get my new intel system. And btw i dont think its a problem to keep the white paper behind the mobo ??? lol have left it all this time nothings happened.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #39 (permalink)
Old August 9, 2008, 03:54 AM
cryostage's Avatar
i would remove it because u never now what can happen LOL shit just might catch on fire lol
  #40 (permalink)
Old August 9, 2008, 12:20 PM
Dashock's Avatar
alrighht alrighht when i redo my loop ill do it i dont think it matters.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Forum Jump
