The Grills on the front have a nice touch they come off by opening the side panel located at the bottom the side panels are held by a magnets. ![]() ![]() ![]() All these individual front grills have a mesh which helps stop dust the effectiveness will be tested as the weeks go by my room gets very dusty the design of this setup in my mind is Excelent i cannot find any flaws with this setup yet so good job Coolermaster.
__________________ Intel Xeon E3110 @ 3.0ghz XFX 8800 GT Alpha Dog Edition Asus P5Q-E Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v OCZ 600W GameXstream Seagate 7200.11 500gb Seagate 7200.10 320gb Antec Spot Cool Logitech X-230 Samsung 32" 720P HDTV Coolermaster Cosmos S/ Swiftech Mcp655/ MCR-320-QP/ 6X Noctua NF-P12'S/ Swiftech Apogee GT/ Swiftech Mcw-60/ Swiftech Micro-Res. |
I have practically the same watercooling setup as you and have been running it in the cosmosS for about 5 months now.It is a great case......... The other night i was gaming when all of a sudden there was a huge bang followed by what can only be described as ball bearings being rattled in a tin can coming from the CosmosS....My first reaction was to shut down quickly (holding the power button down for 4 seconds ) which seemed like an eternity at the time! Opening the case revealed that the 230mm side panel fan had shed two of its blades and decided to throw them around the inside of the case! Well luckily for me (i guess?) there was no damage to other components. There is absolutely no apparent reason as to why this happened there is no hardware or wiring even close to this fan.. and its been running great for the last few months. I've emailed Coolermaster to see what they say , so i guess i will foind out how good there support is ?!
__________________ Motherboard: Intel DX48BT (BoneTrail) Motherboard BIOS: 1554 CPU: Intel QX6700 (Lapped) CPU Overclock Speed: 3.8ghz CPU Cooling: WaterCooled /Apogee GT/Custom Loop CPU Idle Temp: 42 c CPU Load Temp: 64 c Memory: Kingston HyperX DDR3 Memory Speed: 1800mhz Video Card(s): Foxconn 9800GTX Video Card Speed: Stock Sound Card: PSU: PC POWER & COOLING Turbo Cool 1kw Case: Cosmos S |
Just for future refference don't wait the 4 seconds just flip the psu switch
__________________ Amd FX60 @2.9 Asus A8R32-MVP Deluxe 2 Gig Corsair XMS 4000PT 2 Ati X1900's @XTX Speeds 2 WD 160gg HD's in Raid 0 XFi Platinum Tt 680 Watt PSU SATA Plextor DVD (Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's Kandalf |
It was not readily accessable
Yea the powersupply is at the bottom so its not easy to turn it off in that way but theres another reason Loose im glad i took off the side fan and how were yu able to fit the fan im using 7/16 tubing and i ever have a good tight bend i cannot keep the fan and close my door.
My GPU is not WC'd at this point due to the fact that i had a 8800GTX denied warranty because it was WC'd ( it had a bad DVi Socket,nothing to do with cooling) ,i also ran with the windowed side cover at that point which had no fan
I just took of the fan i like it has a mesh filtered side panel this way my inside fans can still get clean air going thru the system id looove to see someone with both their cpu and gpu cooled with 7/16 or 1/2 tubing and the side fan on and did yu find the back rubber holes for tubing absolutely pointless?
The rear holes are not pointless i know people that use coolers such as the corsair nautilus and they are great for those. As for me , all my cooling is internal so i don't use them.....i did run a gpu cooler with that fan and yes it is tight but i used 90 degree elbows to reach the cooler.
Yes Captain vortex used those 90 degrees metal bends in his loop that would technically make it possible. the Use of holes for me is more for being able to get tubes to the back of the case if your mounting an external rad as with other cases but as you cannot do that with this case unless you start cutting pieces of the back fins that is why i dont find it all that usefull.
| Thread Tools | |
| Display Modes | |
