Old May 2, 2008, 03:27 AM
Scratch's Avatar
Level up: 92% Level up: 92% Level up: 92%
Level: 12 - 33 points to level up
Default CoolIT Systems Freezone Elite
CoolIT Systems - Freezone Elite CPU Cooler
I have been an owner and supporter of CoolIt Mtech coolers since I purchased the Eliminator in December 2006 for my E6300. With the influx and consecutive price reductions of Intel chips I soon upgraded to a Q6600 and with it came higher temps so I began looking for my next step up in cooling.
A Q6700 recently came available and the next day I just happened to find the CoolIT Freezone Elite onsale at NCIX for $349.00 CDN a $100.00 savings off the manufacturers retail price. Having experienced the durability and performance available in the Eliminator and the fact that I have never seen a sale price on any model of cooler available from them I decided to jump it.
Now I will not lie and tell you that the Eliminator was a silent pc cooling solution unless you're running stock speeds. If you run intensive games, a moderate OC or are into blazing hot intensive benchmarking or running FaH clients at 100% cpu usage, the Eliminator sounds like a noisy barfridge as it only has 3 temp settings (low, medium, high) and comes equipped with a noisy 90mm fan. The Freezone on the other hand has a nice 120mm fan and is as noisy at 100% fan and pump speed as the Eliminator was at low speed. The freezone at idle has a soft whir to it and I didn't even know my pc was on as I was watching the fights last night
The Freezone Elite comes with a nifty piece of hardware and a software package appropriately named the Mtech Control Center that has as its main feature "predictive cooling technology" a set and forget feature that lets you determine your coolant temperature and the Mtech Control Center (MtCC) will automatically adjust fan and pump speed to regulate flow to maintain your desired temperature and has another nifty 3D graph that allows you to monitor temperatures and usage in realtime
It also has an alarm that will shut down your system incase of pump failure and will email you if it detects pump, fan, software or system shutdown.
It also has 2 controllers so you are able to control your cpu and also a chipset or graphics solution cooler with the same controller
My test system:
EVGA 680i SLI Motherboard
Q6700 SLACQ 10x330mhz 3.3ghz @ 1.3vcore
Mushkin XP-2 Redline 2x2GB DDR2 8000 @ 1000mhz 5,5,5,18 2T
EVGA 8800GTS Scc 640mb @ 620/1500/100mhz
WD Sata2 160GB HD
WinXPpro SP3
I first set my coolant temp at 20c and that seemed to set the fan and pump off even at idle to keep the coolant temps low so I reset at 25c (default) and allowed the predictive cooling feature of the Freezone to take control.
As you can see it did its job keeping the coolant and my cpu at 25c idle 75% fan/pump speed.
I used 4 instances of FaH running 24 hours one instance for each core to stress the cpu and reached 38c 100% load 100% fan/pump speed with a 27c coolant temperature. A mere 13c between idle and load temps with a 25% overclock.
For comparative purposes I used the same FaH configuration on a Q6600 overclocked to 3.ghz @ 1.25vcore and the CoolIT Eliminator running at 100% load hit 68c cpu temp according to Coretemp for an astronomical difference of 30c between the 2 coolers
Conclusion
I was not expecting the efficiency of the Freezone Elite to be so dramatic so am very surprised at the temperatures recorded and the price I was able to aqcuire the unit for. I have not pushed this cpu with any extreme voltage so the overclocking potential is still undetermined, however given the performance at a 25% OC I can only see good things to come and highly recommend this product to anyone willing to spend a few dollars for an enclosed, safe peltier watercooling solution
As an afterthought I decided to see what would happen if I set the coolant temperature to 0c and hit 13c cpu idle temperature after about 20minutes but forgot to take a SS as it was after 2am :)
BUY CANADIAN
EVGA 680i, Q6700 @ 3.3Ghz 1.3v, 3x WD 160GB , 2x2GB Mushkin Redline pc8000 @ 1000mhz CL5-5-5-15 2t
1x EVGA 8800GTS 640MB @ 651/1525/1003mhz, Silverstone Zeuss 750w PSU,
CoolIt MTec Freezone Elite CPU Cooler, SilverStone Tj09 case, Dell 2407WFP Monitor
Old May 2, 2008, 03:11 PM
kruzn4evr's Avatar
Level up: 55% Level up: 55% Level up: 55%
Level: 11 - 153 points to level up
That's pretty impressive!...I himmed and hawwed about getting one too but decided to wait and see what you had to say about it with the new chip (glad it's working out btw)...why did ya take so long??!!...now they're back up to reg price on NCIX...lol...however...it is selling for $365.01 (+$15 shp) Extreme PC maybe I'll go for it, I better(ask the wife)check the funds 1st
Asus Striker II Extreme - qx9650 w/GTZ -2x2GB Corsair DDR# 1600 - 2x gtx 280's w/VID 428 Koolance fc wb's-dual boot
wd vraptor 300gb - wd raptor 150gb - samsung sp 750gb - lg bluray dvd - TT TP 1200w - Koolance drain valve and nozzles
mcp355 w/xspc top - xspc passive res - TT LCS Kandalf case
Old May 2, 2008, 03:20 PM
ebdoradz's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 14 - 272 points to level up
dman,
what a nice setup, and god dman nice temp, 38C full laod on a quad thats hard to beat with water ...
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.8Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Corsair 620W PSU / 2*Seagate 80Gb
DFI LP Nf2 Ultra-B / AMD Athlon XP-M 2500+ @ 2.4Ghz/ CENTON DDR400 TCCD / Evga 6800 AGP / FORTRON 450W PSU / 2* Maxtor 80GB
ASUS A7N8X / AMD Athlon XP-M 1900+ @ 1800Mhz/ Corsair XMS 2*512 / BBATI 9800pro AGP / FORTRON 450W PSU / Maxtor 80GB + 120GB
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old May 2, 2008, 03:21 PM
kruzn4evr's Avatar
Just happened across this review, thought you might like it [H] Enthusiast - CoolIT Freezone Chilled Liquid CPU Cooler
Old May 2, 2008, 05:29 PM
Scratch's Avatar
yea nice review a little more indepth on the hardware side but that is also for the Freezone, not the Elite edition that has addressed the problems mentioned in his review. The Elite has a 120mm fan (very quiet) and the included Mtech controller has dual ports so that you are able to hook up another loop if you wish. I'm thinking of buying their graphics card cooler
The main reason I posted was that I had an issue with the Mtech controller not recognizing my USB so went to the CoolIT forum to see what was up (found out it was due to my MCCremoteservices not running) but some dumba$$ had posted how this thing wouldn't cool a quadcore. Obviously it cools it quite efficiently and yea I'm impressed lol
This waterblock could be lapped and probably take off another 3-4c and its now been 2 days and I think the AC MX-2 has set because the temps have actually fallen another 2c at load over the last 14 hours.
I would have posted sooner but tourist season has started so have been a little busy in Victoria :). Haven't even had time to do the new ram or play with the cpu to its potential
Old May 2, 2008, 05:50 PM
kruzn4evr's Avatar
Well, like I mentioned, I'd like to get 1 for my qx9650 but I just ordered 2 780i mb's, 2 E8400's, 2 9800GTX's and 2 OCZ 700w SLI PSU's from NCIX and still need HDD's, ram and dvd drives for a couple of systems I'm building so funds are getting a little thin..lol...hopefully next mth if all goes well, I'll check with ya to see how yours is holding up
Well, I couldn't wait!...I ordered 1...lol
Old May 16, 2008, 07:28 AM
kruzn4evr's Avatar
How's the Q6700 and the coolit elite holding up?....I tried ordering 1 but got jerked around by..I won't mention the company, lets just say they were VERY unprofessional and I was "EXTREME"ly disappointed. Anyhow, I decided to take the plunge (pardon the pun) and purchased a WC kit from NCIX, should be here anytime now so if I don't post again in the next few days?...I did it wrong and fried it ....lol
Old May 16, 2008, 07:34 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Hardware Canucks will have a review of the Elite up shortly but until then, this is a great little review.
Old May 19, 2008, 09:42 PM
Level up: 86% Level up: 86% Level up: 86%
Level: 9 - 34 points to level up
Nice.
I had the Freezone [regular] a while ago, but returned it since it was way too loud.
At with it set to quieter, it wasn't even better than air.
Thank god they finally figured out it needed a 120mm fan.
Old May 20, 2008, 05:42 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Location: Toldeo Ontario (half way between Ottawa and Kingston)
As a small sneak peak: the fan that comes with the Elite model w/ mtec REV 2 controller is very NICE. Even & 100% load the noise it creates is mainly wind noise. Which makes sense as its moving 120cfm! Under 60% load it makes less noise than a Scythe E and .... thats all I'm saying for now ;)
Test System 1: Q9450/ Coolit Freezone Elite/ Asus Maximus Formula/Mushkin HP2 4GB 6400/ VelociRaptor / WD Se16 640gb/ Samsung 203b/ Plextor 755/ XFX 7200gs
Test System 2
: Q6600/
Vendetta 2 w/ Noctua NF-P12/Gigabyte GA-P35-DS4/ WD SE16 320gb/ 4GB G Skill 6400/8800 GT / Samsung 203b
939 System 4400+ @ 4800 / 2 gb Twinx/ Evga 7900gtx 512mb / Plextor PX 716 / 2 PX 760 burners / Raptor 150 / 2x Seagate 7200.10 320's / WD Se16 500
www.nopperdogs.com
Forum Jump
