  #21 (permalink)
Old June 15, 2008, 05:39 PM
DK2 DK2 is offline
Originally Posted by cegras View Post
Sorry to bump, but what I found funny when looking at the reviews is the way the TEC is attached to the heatsink. Why don't you have a solid plate with fins radiating out of it? Instead you have the TEC contacting the radiator at each fin point .. or I'm seeing something wrong.
Don’t know how you could say that, he didn’t break open those blue TEC’s.
They seem to be strapped right on the heatsink, and the water flows right in there,
I would assume they made it so the heat transfers to the heat sink to be exhausted from the system and not the other way around.
Maybe I misunderstand what you mean.
  #22 (permalink)
Old June 15, 2008, 07:42 PM
cegras's Avatar
http://images.hardwarecanucks.com/im...e/fins2_sm.jpg
Hopefully HWC doesn't mind me hotlinking their own picture. But as you see here, it appears the TEC's aren't making the best use of the radiator.
  #23 (permalink)
Old June 16, 2008, 03:50 AM
Oh well! This review plus the one released by Hardware Canucks convinced me... I just ordered one from NCIX (at a special price of 349$ untill June 17th ) to replace my TRUE ! Can't wait to install that baby !!!
Lapped Intel Qx6850 @ 3.7 Ghz @ 1.4 volts
Coolit freezone elite
Asus Rampage Formula
8 Gig Gskill pc2 8000 4x2gig
HIS HD4870X2
BenQ V2400W monitor
Pc power and cooling quad 750
Cooler Master Stacker 830
  #24 (permalink)
Old June 17, 2008, 08:39 PM
Holy shit !!! That thing is awesome !!!
Take a look at those idle and load temps.
HIS HD4870X2
BenQ V2400W monitor
  #25 (permalink)
Old June 18, 2008, 06:14 AM
DK2 DK2 is offline
Okay, from that pic I can see what you mean, I just picked mine up this morning,
so I’ll take a look after work.
  #26 (permalink)
Old June 18, 2008, 03:43 PM
DK2 DK2 is offline
Well, your right that’s exactly what it looks like, the HWC review pics are pretty accurate, however….
Considering the TEC is just a plate, attaching it directly to the fins
should actually increase the thermal transfer rather than have buffer plate in-between as you suggest.
I’d consider it a kind of hybrid, the normal heat sinks you see are a mounting plate with fins, this already has the plate, you just need the fins.
