Old October 8, 2013, 08:39 AM
sswilson's Avatar
Is the first post now visible to everybody?
This is one of those times where a previously moderated post is edited after it gets approved. That can sometimes throw it into moderation / approval hell/limbo where it appears to be approved to staff, but the system blocks it from general view.
Old October 8, 2013, 08:54 AM
I see it now!
Back up - Ebay (Inik1) or Heatware
Old October 9, 2013, 04:15 AM
Thanks for fixing the post.
Thanks for liking this review (and the work behind).
This is the beginning of a large radiator review.
AMS 360 Al already added.
MoRa 3 9*140 vs. 4*200/4*230/4*180 is ready to start. Effekt of shrouds on large fans, push/pull effect etc.
Old October 9, 2013, 05:24 AM
Default Mora 3 9*140 (NB PK-3, pull)
A short view on a MoRa 3 experiment without and with fans added one by one at 460 W.
Result:
no fan give the option to cook the circuit (I stopped at 50 C hot water side since ther was no trend to get a equilibrium)
one fan is better than no fan (what a conlusion..) - no temperature increase
3 fans can reduce the water temperature by 16 K.
9 fans can reduce the water temperature by 23 K.
Graph shows that fanadapter 3 was not at max speed (or maybe the fan is not a PK-3???)
Every of my measurements are compared with a snapshot of such curves.
Enjoy. :)
Old October 10, 2013, 03:36 AM
Trial Member
Hi GliderHR (and everyone else here!; I joined today),
Excellent posts and thorough measurements. Looking forward to the 4 vs 8 large diameter fan measurements on the Mo-Ra, and which fans you've selected. The choice for these large diameter fans isn't that great. I'm putting together my system and getting the Mo-Ra with the new 4x fan mounts. I'm waiting for Noctua to release their 200 A-series fan, which is planned for beginning of 2014, and will need to find a stop gap fan until then. Right now, based on data, looks like I'm going for four of the Phobya 180 700rpm fans, although that may very well change when I see your data. When I get the Noctuas I'll have an extra four fans, so for this reason I'm contemplating whether it's worthwhile to get an extra 4x fan mount for push pull. Thanks again for doing all the measurements!
[Bundymania User Review] 4x 1080 Monster Radiator - Roundup bundymania Water Cooling 0 March 25, 2013 10:25 AM
[Bundymania User Review] Triple Radiator (360) Roundup with 22 Rads ! bundymania Water Cooling 0 October 1, 2012 10:32 AM
[Bundymania User Review] Triple Radiator (360) Roundup ! - 16 Rads bundymania Water Cooling 3 February 11, 2012 03:55 PM
Hybrid Silent and High Efficiency Gold Metal PSU - CORSAIR AX750W Review windwithme Member Reviews 8 June 10, 2011 07:31 AM
Q9300 review by X-bit labs yycraven Reviews & Articles from the Web 6 March 24, 2008 08:39 AM
