<~----> Soullessone21's MSI 660Ti PE Review - Page 2 - Hardware Canucks
Old August 16, 2012, 11:32 AM
That card looks very nice. Would look even better with my msi motherboard. How much of a bottleneck would there be (if at all) when paired with an amd 955 processor?
Old August 16, 2012, 11:34 AM
Soullessone21's Avatar
What overclock are you running? if its mild then the CPU might slow you down but if ur around the 4Ghz mark then the 660Ti PE is probably right where you want to be for most gaming. Its a great mid range card and I cant stress how dead silent it is enough :D
Current Build:http://www.hardwarecanucks.com/forum...cube-gods.html
Always up for a Beer in Calgary or Area
“Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.”
Old August 16, 2012, 08:04 PM
I'm using stock speeds right now. Better save up for a cooler so i can overclock it then.
Old August 16, 2012, 08:11 PM
highly recommend the noctua 14 series
Old August 16, 2012, 08:28 PM
ZZLEE's Avatar
Time to start saving pennys :)
Nice review Thanks >
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old August 17, 2012, 11:00 AM
Thanks means a lot and go with the MSI one due to the fact its so nice looking and runs like a champ.
Might replace my 670 with two MSI660TI PE's for a nice sli setup
Old August 17, 2012, 03:08 PM
dandelioneater's Avatar
Nice review Soul! Must be alot of work to do up a decent review . I especially like MSI's heatsinks and the fact that the power connectors are located on the end of the pcb instead of the middle like the on the reference cards. I couldn't imagine how awkward routing cables would be to the middle of the pcb.
Old August 17, 2012, 03:28 PM
SugarJ's Avatar
Actually, the power connectors are at the end of the PCB on the reference 660 Ti's, it's just that the fan shroud protrudes a couple inches past the board that makes it look like it's in the middle.
  #19 (permalink)
Old August 17, 2012, 03:46 PM
Oh wow thanks so much really appreciate the kind words. Cable management with the 660ti was super easy but even with my 670 EVGA with the tiny PCB and huge shroud the cables were not so bad I just stuck a cable management snap to the fan housing and ran the 6 pins along that haha
Very true and those mini PCB's are awesome when water cooled they free up tons of room to do nifty things with your extra space like a nice mini rez
PS your avatar pisses me off as it makes me always want to go play fallout haha And no deals for you with the barter perk pip boy :P
  #20 (permalink)
Old August 17, 2012, 10:36 PM
Are you going to watercool yours?
WIP Mechwarrior Build*Reserved* Soullessone21 Case Mods, Worklog & Gallery 8 May 4, 2012 05:53 AM
Half of my ram is reserved for hardware. HELP!!! Saulkar Troubleshooting 10 December 21, 2011 11:47 AM
Buying parts tomorrow for SB tomorrow! tl9015 New Builds 2 January 16, 2011 03:05 AM
Deleted System Reserved Partition Malam Storage 4 December 31, 2010 05:46 PM
UFC 102 tomorrow night badatcards Off Topic 0 August 28, 2009 03:16 PM
