Old March 18, 2008, 10:01 AM
Misoprostol
Guest
Posts: n/a
Default nVidia GeForce 9800 GX2 1GB Dual GPU First Impressions
nVidia GeForce 9800 GX2 1GB Dual GPU Video Card
"First Impressions"
Product: nVidia GeForce 9800 GX2
Price: MSRP: $649
Availability: March 18, 2008 - allocated
Introduction
The 9800 has been unleashed! Please note that this is not a re-release of ATi's Radeon 9800, but rather a new sort of "9800" ;)
nVidia has finally lifted the veil on their new enthusiast class dual GPU beast: the GeForce 9800GX2.
As if using the "9800" moniker was not enough, some of nVidia's partners (including eVGA) have even gone as far as to feature the card in red and black retail packaging that is very reminiscent of the discontinued "Built by ATi" cards. The message they're trying to send is unclear, but we are certain it's no accident….
We just got our sample, so this is only a first impressions, and NOT a full review. In the full review we will be re-running all of these tests on the 9800 GX2 with the most current drivers available at that time. The full review will also include our entire benchmarking suite against a wider variety of competitors. For now though, we're a little short on time, so we're going to have to make do with a battle of the heavyweights: The GeForce 9800GX2 vs. the Radeon HD 3870 X2.
Notes about the card
There were a couple of things that bothered us about the setup process, particularly when were just getting started. First of all was the fact that the 9800GX2 uses a 6-pin and an 8-pin PCIe power connector. This in an of itself is not a problem, but unlike ATi's HD 2900XT and HD 3870 X2, the 9800GX2 will not power on with two 6 pin PCIe power connectors plugged in. You MUST use an 8-pin power connector. Those of you with older power supplies, get ready to upgrade or find an adapter.
One neat feature that enabled us to easily troubleshoot this problem was nVidia's inclusion of an easy way to tell if the GX2 is getting enough power. Simply check the LEDs built into the power connectors. Red means that it's not geting an adequate supply (no plug, or 6pin into 8 pin), and green means that it's getting enough power.
There was another problem with the 8 pin power connector on the card and the 8 pin power connector on our Corsair 520HX tester power supply. Every PCIe power connector has a little clip that serves to hold it in place, but not all of them are directly centered on an 8 pin connector, so if you have a 6+2 connector like the Corsair unit we're using, you may have a conflict. The solution we came up with for the sake of running our benchmarks was to cut the clip off, but this is not an ideal thing to do....
you can see the conflict between the clip on the power connector and the video card
Also interesting to us, since we don't have the nVidia launch materials, is the SLI connector on this card. Until we physically saw the card we weren't 100% sure that nVidia would take another crack at Quad SLI, but it looks like now that AMD has managed to somewhat successfully launch Crossfire-X drivers, it's time for nVidia to make another attempt. Hopefully the support is a little bit stronger this time around.
Also of note was the fact that with the drivers on the CD we had to manually enable SLI in the control panel, but with the BETAs we used, this was not necessary. Some complaints have been spotted on the web about this issue, but it looks like nVidia intends to fix it. Also of note about the disc drivers is that Company of Heroes performance was improved dramatically with the BETAs, but nothing else we tested was affected beyond margin of error.
Test Setup and Methodology
All tests were run at highest in game detail settings with V-sync disabled.
Catalyst 8.3 was used for the HD 3870 X2 and the latest BETAs were used for the GeForce 9800GX2 (174.53). You can expect the full review to be using a more mature driver set, but honestly things didn't seem too buggy in our limited testing.
The 9800GX2 was connected to our 24" test monitor via DVI. The HDMI output on the back was not tested. The card came with what looks like a digital pass through cable of some sort, so it appears nVidia might have a trick up their sleeve for enabling digital audio via HDMI.... Stay tuned.
Test Bed:
Asus Maximus Formula X38
Intel Core 2 Extreme QX6850 @ stock speed (3.0GHz quad core)
2x1GB Mushkin XP2 PC2-6400 4-4-3-10 (D9)
Corsair 520HX power supply
Seagate 7200.10 500GB
Samsung SATA DVD+-RW
Windows Vista Ultimate x64 (fully patched)
Test Games:
Company of Heroes (1920x1200 DX10 max everything 0xAA/0xAF)
Supreme Commander (1920x1200 max everything 0xAA/0xAF)
Half Life 2 Lost Coast (1920x1200 max everything 0xAA/0xAF)
3Dmark 2006 (1280x1024 all options default)
Crysis (1920x1200 64-bit max everything 0xAA/0xAF)
Obviously we're not testing either as many games as usual. The reason for that again is that this is a first impressions, not a review. We're keeping things very simple just to give everyone out there some idea of how well this card performs until we've got the time to run our usual battery of tests.
Since the 8800Ultra, there hasn't been an enthusiast-level product released by nVidia and the 9800GX2 has finally come to fill that void. The 9800GX2 feels like a much more elegant dual GPU solution than its predecessor the 7950GX2, and performance looks pretty good compared to its closest competitor: the Radeon HD 3870 X2. The 9800GX2 won most of the benchmarks we ran, but as mentioned before, this is just a first look, and there will be much more in depth testing available once the full review hits. Look to see more games, more resolutions, and more fun….
All of that said, we have gone to the usual lengths to ensure the accuracy of our benchmarks. Every test was run three times, then the results averaged, and all tested games and programs were fully patched.
Benchmarks
3Dmark 2006 Professional
Crysis 1.2
Company of Heroes
Supreme Commander
Half Life 2: Lost Coast
Conclusion
Since the discontinuation of the 8800Ultra, nVidia has not had an uber-enthusiast class video card. The 9800GX2 has come along at a very good time to fill that void. The 9800GX2 feels like a much more elegant dual GPU solution than its predecessor the 7950GX2, and performance looks very favorable against its closest competitor: the Radeon HD 3870 X2.
The 9800GX2 wins most of the benchmarks we've run, but as mentioned before, this is just a first look, and there will be much more in depth testing available once the full review hits. Once we've looked at the card with more mature drivers instead of early BETAs and run a more complete benchmark suite, we'll be able to draw more conclusions, but for now we can tentatively say that nVidia has regained the single card performance crown.
Review by Misoprostol
Old March 18, 2008, 10:11 AM
biff's Avatar
So is someone going to take the cover off that b**** and see what's inside or what? It looks like aftermarket cooling is out of the question.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old March 18, 2008, 10:22 AM
Cardboard box with DSL's Avatar
When can we see a 'review' rather then just a first impressions?
Old March 18, 2008, 10:27 AM
magictorch's Avatar
If Crysis is a good indicator of future games then this is a nice card!! Although Id like to see what the new GTX can do.
Old March 18, 2008, 10:31 AM
Mr. Cipher's Avatar
Looks like it will be a decent performer, especially at those higher resolutions (no need for SLI then with that beast).
Can't say I am too fond of its clunkiness. Its one, big, giant box of GPU.
**Edit: must be some forum error. How did my post become #1?**
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Old March 18, 2008, 10:32 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
The time on the original post is off completely so any posts that come after it will actually be put...before.
Cptn Vortex's Avatar
Yeah I want to see how it compares to a 3870 X2. In some preliminary test I saw it losing to the ATI, (Crysis, hi res, high settings, the only benchmark that matters to me), and in some, like this one, it killed the ATI card. Hmmmm.... my GTX is getting old, and it's almost tax time!
I think the forum doesnt understand how time zones work.
The Vortex H20
EVGA SR-2 Classified
2 x Xeon L5639 Hexcore CPUs, 3.2GHZ
EVGA GTX 580 - 940/2115
24GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 90GB Corsair Force SSD RAID0
Sharp 32" Aquos 1080p
Benq W500 Pojector.
Watercooling:
2 x EK Supreme HF, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, XSPC GTX 580 FC block, EK Coolstream XT 220 RAD Gelid Wings Push - CM R4s Pull.
Old March 18, 2008, 10:34 AM
Babrbarossa's Avatar
In the benchmark graphs- you're calling it an 8800 GX2
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old March 18, 2008, 10:35 AM
Beermaster's Avatar
NVM Babrbarossa beat me too it :D
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov – Acer One*8gb SSD*WinXP pro
Tathar – WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
Old March 18, 2008, 10:36 AM
SKYMTL's Avatar
*looks again*
Isn't that what it REALLY is?
GeForce 9800 X2 pics! Babrbarossa Press Releases & Tech News 27 January 16, 2008 12:57 PM
Swiftech Introduces it's new waterblock for NVidia GeForce 8 series Babrbarossa Press Releases & Tech News 1 June 3, 2007 01:54 PM
NVIDIA Plans For GeForce 8800 Ultra? Babrbarossa Rumor Mill 7 March 5, 2007 02:03 PM
nVidia GeForce 8800GTS 320MB Reviewed @ TrustedReviews Supergrover Reviews & Articles from the Web 0 February 13, 2007 04:18 PM
HardwareZone has Nvidia GeForce 8800 GTX buying guide & shootout Supergrover Reviews & Articles from the Web 0 December 14, 2006 07:04 PM
