<~----> Scythe Ninja --> Scythe Ninja Copper - Page 2 - Hardware Canucks
Old February 27, 2008, 08:18 AM
vinister's Avatar
lol about the camera, its like a $199 Canon - point and shoot for old ladies. Macro-mode, vivid colors, no flash. thats all!
The original Ninja had a terrible base, after using it once it was all tarnished. It also had some pretty deep scratches, so I decided to sand it clean. What a horror show, from the first pass on the sandpaper, I could see the base was as wavy as the ocean. it probably had less than 10% contact because it was so wavy. I hit it with 600grit, 800grit, and 1000grit, then used some polish on it. It helped alot, I was also getting 70 degree temps before the lap, and it came down into the low 60's area.
The tests I posted above were about 10 minutes after applying thermal paste. As of today, my idle temps have dropped a couple degrees, but my load temps are down to 47!! Now I'm starting to really be impressed! I'm going to give it a few more heat/cool cycles then do another bench.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old February 27, 2008, 10:13 AM
vinister's Avatar
here are the final results now that the AS5 has set in. I'm not used to seeing this much difference!
Ninja Rev. B load temp: 57c
Ninja Copper load temp: 47c
I'm very pleased ;)
Mobo: DFI 790X-M2R
Old February 27, 2008, 10:19 AM
Prof. Dr. Silver's Avatar
You might want to try and get your hands on some MX-2 by Arctic Cooling. That will lower your temps even more!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Scythe Ninja Copper Review Comment Thread SKYMTL Air Cooling 16 June 14, 2010 09:55 PM
Scythe Ninja Rev B. for those considering it - lots of pics 56k warning! low351 Air Cooling 17 March 28, 2008 07:28 PM
Scythe Ninja Plus Rev. B BALISTX Air Cooling 2 May 5, 2007 11:28 AM
