StreetFighter IV Benchmark
1280 X 720 => 47.49 FPS
DEVIL MAY CRY4
1280 X 720 => 48.49/43.25/57.83/33.63 fps
FINAL FANTASY XIV
1280 X 720 => 881
Using the H67H2-M BIOS overclocking GPU functions to achieve more than 34 times overclocking speed shows that the HD3000's overclocking capabilities are not to be underestimated.
Generally speaking, overclocking to 1700 ~ 1800MHz is not too difficult.
After overclocking, 3DMark Vantage has a nearly 50% performance improvement.
In other areas, StreetFighter IV has gains of about 20%, and DEVIL MAY CRY4/FINAL FANTASY XIV, about 30%.
For benchmark games such as 3DMark Vantage to have such great 3D performance, consumers should be more satisfied.
The improvement in audio and video performance is a major feature of Sandy Bridge.
Next, we tested Intel's new Quick Sync Video Technology,
MediaEspresso to compare the built-in GPU and external VGA and the time required for video conversion of a DVD file called VTS_01_1.VOB with a size of 1023MB, 2500K into an MP4 file.
Intel HD Graphics HD3000
Turn on Intel Quick Sync Video (better quality)
6 minutes 49 seconds
msi N560GTX-Ti Twin Frozr II
Using nVIDIA CUDA technology
8 minutes 09 seconds
For this file, Intel's Quick Sync Video was 1 minute 20 seconds faster than the nVIDIA CUDA.
If you use an external VGA with CUDA and switch to Intel's built-in HD3000 H67, you get a time improvement of about 37% or more.
If you are using external VGA, you cannot take advantage of the Intel Quick Sync Video technology. This is something you need to be aware of.
In addition, with the two file conversion technologies, video performance is also something we care about.
In the future, I will carefully note the differences.
Video playback test
With movies on hand that I've bought, I used Blu-ray versions of “Inception”. The copyright for the above video belongs entirely to the owner.
With a Blu-ray movie, you have to use PowerDVD mode, and on a Windows desktop, it's not easy to do a video capture, so a direct capture screen is used as a reference here.
The CPU utilization rate is approximately 13 ~ 20%, and with the HD resolution of 1920 X 1080, video playback is smooth.
ECS H67H2-M
Advantages
1. H67 is a more high-end product with attractive packaging materials and good accessories
2.15μ gold contacts, Realtek RTL8111E chip, USB 3.0/eSATA and other materials
3. BIOS overclocking with the GPU provides features that set Sandy Bridge's 3D performance at a higher standard
4. 2500K with satisfactory power consumption performance and overall performance also at a high level
5. Qooltech III for dual heat-pipe thermal module, built-in debug LED and POWER / Reset button
Disadvantages
1. The recommended BIOS option is to turn on the DDR3 clock, allowing the user the freedom to choose 1066/1333
2. The surface area of the heat sink near the CPU is too large, and if you want to install a better cooling device, there may not be enough room.
3. Compared with other first-rate MB factories, in the future, expansion of retail channels and repair services by ECS will provide greater convenience to consumers, both areas they care about.
Performance comparison ★ ★ ★ ★ ★ ★ ★ ★ ☆ ☆
Materials comparison ★ ★ ★ ★ ★ ★ ★ ★ ★ ☆
Specifications comparison ★ ★ ★ ★ ★ ★ ★ ★ ☆ ☆
Appearance comparison ★ ★ ★ ★ ★ ★ ★ ★ ★ ☆
Price to performance comparison ★ ★ ★ ★ ★ ★ ★ ★ ☆ ☆
The performance of the H67H2-M launched by ECS is very good in all respects.
With the BIOS, if more DDR3 options can be added, that will be an improvement.
Specifications and materials of the H67 compared with those of other MB manufacturers are fairly standard.
The scalability enabled by the dual network features of Micro ATX, USB 3.0 and eSATA creates a high-end PC host.
The price of US$149 is equivalent to NT$4,372.
For these material standards, the high-end H67 is a bit pricey.
Compared with other MB brands, the H67 is a bit expensive, yet the price to performance of the ECS H67H2-M is fairly good.
The integrated Sandy Bridge chipset's great value in the future should be targeted at the H61, allowing more room for pricing.
Regarding the Intel 6 series chipset bug incident, ECS on February 7 issued a statement on its website.
The company halted shipments of the Sandy Bridge B2 version, and the company will unconditionally replace all sold goods with the B3.
This policy and those of other top-line MB manufacturers is very sincere in the hope of keeping the design flaws of the P67/H67 to a minimum.
The entrance of the Sandy Bridge architecture to the market has enabled the performance of Micro ATX MBs and multimedia to make very clear steps forward.
The conversion efficiency of Intel's Quick Sync Video is especially impressive.
For those consumers who prefer a small PC host this is a great benefit, but prior to the H61's market debut, the H67 is a higher priced option.
This report shares specifications and descriptions of all aspects of the ECS H67H2-M's performance as reference for consumers. :)
This review also post in my blog
WIND3C
Welcome 3C lovers to visit and advise.
