-   Member Reviews (http://www.hardwarecanucks.com/forum/member-reviews/)
-   -   MSI R5870 Lightning II mini review (http://www.hardwarecanucks.com/forum/member-reviews/37007-msi-r5870-lightning-ii-mini-review.html)
Dogger1 October 12, 2010 07:16 AM
1 Attachment(s)
The original version of this card was MSI's first AMD gpu based card, in the Lightning series. However, as first attempts are famous for, they didn't quite get it right; hence the Lightning II.
Note: The vast majority of the reviews on the net are of the first version, which wouldn't overclock worth a darn, and you have to look long and hard to any reviews of the II.
MSI refers to this card as a "Military Class Concept." They use Hi-c tantalum capacitors, solid chokes and gold plated connectors, which would indicate that their built to perform and last.
I'm running 2 of these cards and with Afterburner I've been able to overclock the setup to Core 985, Memory to 1250, with the fans set at 100%. One point of note, @ 100% the fans aren't all that noticeable.
I ran 3DMarks Vantage, with the following results:
Graphics Score 32313
Jane Nash 97.22 FPS
New Calico 91.99 FPS
ORB - Compare
This mini review is indicative of that a single Lightning is capable of MSI Lightning II R5870 - Overclock.net - Overclocking.net Since my 950 is air cooled and I'm running two of these cards, I can't quite duplicate his overclocks but my results have been stone cold reliable.
FYI, my 950 was oc'ed to 4000 MHz, with HT enabled. The highest CPU temp reported by RealTemp was 74c and according to Afterburner the highest temp on either of the cards was 65c.
The reversions to the Lightning II, from the original version are in the area of cooling:
Ikthus October 13, 2010 10:27 AM
Thanks for the review. What voltage did you need to reach that OC?
The price for this is a real turn off though, at $439.99 I'd rather spend a little extra on a 5970 or 480.
Dogger1 October 14, 2010 03:01 AM
1.295 volts.
I currently live in the states and was able to pick up a brand new one from Newegg for $359.99 and then a week later I managed to score an open box one for $310.99.
FYI, the reason I did this upgrade was that I was able to sell my ~ 2 year old GTX 285's for $250, per, which I thought was a pretty good deal.
