Old August 31, 2010, 01:25 PM
martin_metal_88's Avatar
I was just wondering Meta, what is the system you are running in the case and how it is about temp and silence?
Old August 31, 2010, 01:39 PM
CMetaphor's Avatar
Quadfather
Those questions will be answered once I get some pictures in . But in a nutshell: Athlon X4 635 under a Scythe Orochi, 780GX motherboard. Just remember that silence is subjective... but in My Opinion, the "quiet" Yate loons I installed in the top of the case are too noisy and vibrate the case too much to be used at full speed - theyre running @ 7v now and are Okay for the moment. I'll be replacing them soon though, as I don't like using fan controllers when I can't easily control them (using Fractal's PCI slot fan controller right now).
Old August 31, 2010, 01:50 PM
Yate Loons aren't great for silence altogether. You'd be better off grabbing some of the medium or low-speed Slipstreams from DirectCanada.
Old August 31, 2010, 02:14 PM
CMetaphor's Avatar
Quadfather
Ill probably pick up some Gelids, Nexus', Enermaxs, or similar. No leds tho.
Old February 18, 2011, 02:19 PM
After looking long for a perfect file server case I ended up picking the R3 black pearl. Now, I have to say that it was a abd choice. I have no idea about your's but the mobo stand off one mine are a bit off track and also the marking near them is wrong. Dosen't matter to me but someone with less experience would put some stand off in hole that will end behind the mobo isntead of under the mobo screw hole. Which would make a short. 2 of them are marked as ATX when they are definatly not. I also found that the plastic feet were pure crap. Mine have a broken feet and a seocnd one is cracked. But the box is in perfect condition. I suspect the screw used to fix the feet were to tight causing the plastic to break during shipping. I also endend in a little issue with the side panel noise canceling material wasn't sticking to the panel. After all this, I will go back to my local shop and get another case because I'm anoyed with that case.
Old May 12, 2011, 06:04 AM
Just bought the R3 Black Pearl. I haven't had any of the above problems.
Old December 12, 2011, 03:54 AM
Thank you for the candid evaluation of this case.
I was going to get one but an air filter that doesn't fit right and and grommets that fall out at will plus a flimsy top case section..as a trade worker I have dealt with that stuff all to often... no thanks
I just modded my old Antec P180B and made room for more wires behind it instead for now.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Fractal Design R3 First Arrival FiXT Press Releases & Tech News 10 August 12, 2010 01:02 PM
Fractal Design Define R2 - Black Pearl mattlef Cases 97 July 26, 2010 02:34 PM
Fractal Design - Define R2 - Member Review mattlef Member Reviews 18 March 4, 2010 01:29 PM
Fractal Design - Tesla and Newton PSU's mattlef Member Reviews 11 February 24, 2010 07:30 PM
Can't wait till I can do this.. Wheee!!! Bognostraglum Off Topic 1 August 11, 2008 12:46 PM
