Old November 15, 2007, 06:26 PM
stoanee's Avatar
Default Thermalright Ultima 90 review
Thermalright Ultima-90 775 Heatsink Review
Manufacturers product page-
Thermalright Ultima 90 heatsink
Product Number-Ultima 90
Price-
$37.80@Directcanada
Availability-In stock
This review showcases the Thermalright Ultima 90 775 cpu heatsink that has won rave reviews on "the net" I decided to buy and install one as part of my upgrade path that will eventually lead to an overclocked quad gaming system. As part of the package I also purchased a Scythe S-FlexSFF21E 120mm fan to use in conjunction with the Ultima 90.
Feature (from Thermalright website)
  • Six-heatpipe design for extra fast heat transfer
  • Stepping fins to hold 92mm/120mm fans
  • Light and easy installationHigh performance, low noise level at competitive price
Technical Spec.
Dimension:L115 x W55 x H139 (heatsink only)
Weight:460g (heatsink only)
Motherboard Compatibility
INTEL: All Intel Socket LGA775 processors
AMD: Athlon64 / FX / X2 / Opteron Socket AM2 processors
Socket 939 compatible with 939 Bolt thru kit , sold separately.
Packaging and Accessories
Include in the kit is mounting hardware for Intel socket 775 and AMD AM2 cpus, thermal compound, 120mm and 9omm fan clips and instructions. I found the instructions clear and easy to use. The installation went witout any problems.
System used
Processor-Intel Q6600 (stock)
Processor cooling-Thermalright Ultima-90 775
Motherboard-ASRock 4CoreDual VSTA
Ram-
Buffalo Firestix FSX800D2C 2x 1gb.
Harddrives-WD 500 gb SATA2-Maxtor 200 gb IDE
Case-Coolermaster Elite RC-330
Case cooling-2x120mm Coolermaster fans
PSU-
Corsair 620
Graphics card-ATI X800XL
The first thing I did prior to installation was to get some "prior"
(stock Intel cooler) temperatures to compare the "after" (Thermalright Ultima-90) temperatures to. I started by picking up a cheap indoor/outdoor digital thermometer to monitor ambient temperatures outside and inside the computer case.
Stock Intel heatsink\fan
The numbers I recorded with the indoor/outdoor thermometer were:
Ambient room temp 20.7C
Inside case temp 28.1C
Then using core temp I recorded the processor temperatures while folding with the Windows SMP client...... (the numbers are hard to read but they are 68C 67C 69C 69C)
and then added four instances of the Orthos utility to drive temperatures up.(73C 71C 73C 71C)
Once I had established those numbers I began the install of the Ultima-90.
I removed the motherboard to facilitate the install of the strengthening backplate,and, as you can see by my photo, I had good coverage on the stock Intel heatsink with thermal compound.
I installed the 775 back plate,
the 775 upper side plates,
and installed new heatsink and fan using Arctic Silver 5 thermal compound.
Once that was all done I put the unit back together (also did some cable management that I was putting off) and fired it up.
I then compared the new readings with the same parameters that I had initially used.
Thermalright Ultima-90 heatsink
Recorded with indoor\outdoor thermometer;
Ambient room temperature 20.4
Inside case temperature 23.5
New temps folding (51C 48C 50C 49C)
And stress testing (56C 54C 56C 54C)
Well it is clear that there is an overall temperature drop, even inside the case! This, of course is partly due to the orientation of the heatsink fan which blows directly onto the exhaust fan at the rear of the case. The graph comparing the two coolers tells the tale:
Based on a temperature drop that averages 18.75C while folding and 17C while folding and running Orthos, I would say this is a very effective cooler and I rate it "HIGHLY RECOMMENDED!"
Next step.. install a 8800GT video card (if it ever gets here), upgrade mobo and get overclocking!
(My apologies for any poor quality graphics and any blatant format copying, I will get better as I learn how to use this website.)
heatware
Old November 15, 2007, 07:04 PM
Cptn Vortex's Avatar
Nice! Very good results, for such a small cooler (compared to it's big brother)
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old November 15, 2007, 07:56 PM
3.0charlie's Avatar
Nice review! Is this one for the tryouts? If so, you should rename the title to "Reviewer Tryouts: ....".
John
Old November 15, 2007, 08:13 PM
Supergrover's Avatar
John
I dont think he can, I think it needs a MOD to do it.
If so let me know and I will do it for you.
Nice Review BTW!
What TIM did you use? The same for both heatsinks?
R.I.P.
Old November 15, 2007, 08:15 PM
Prof. Dr. Silver's Avatar
Default Go for it!
If I may suggest something....Have you tried what the difference would be while running stock and overclocking? See how much higher you can go with your new Ultima 90 when you overclock your CPU! And you should join the contest for sure....Just make sure you're not becoming better than me......LOL Prof. Dr. Silver
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old November 15, 2007, 09:57 PM
Excellent review stoanee. Here is an image of mine with a 92 mm Antec Tricool:
Old November 15, 2007, 10:15 PM
stoanee's Avatar
Thanks for the kind words folks. I do not want to try out for the reviewer thing as it gave me a headache just to do this one. I notice too many mistakes and omissions.
*Super Grover* I used Arctic Silver five on both the intel and Thermaright heatsinks. Also, I am not sure what a MOD is.
*Prof Silver* I do not have the right mobo yet but I will for sure post results when I get one and overclock this unit. I also have another Scythe fan that I want to pop on the other side of the heatsink and see if that makes a difference. I do not have more 120mm fan clips though so I will need to come up with something.
*cyclo* Nice clean layout you have there!
heatware
Old November 15, 2007, 10:39 PM
Asspigeon's Avatar
Both of our avatars are birds, that is all.
Old November 15, 2007, 10:58 PM
No dude! Headaches are normal...that's just a little part of all the fun!
Thermalright HR-03 GT Review Comment Thread SKYMTL Water Cooling 9 April 10, 2008 01:52 PM
