Old November 20, 2007, 08:20 PM
Mr. Cipher's Avatar
Originally Posted by Babrbarossa View Post
That's some amazing overclocking- That's quite outstanding that you reached 3 with stovk voltage- It sort of sounds as if you were using stock cooling, bit you must have been using tghe Ultra 120 in your sig, no?
Great review- very polished
First off, thank you I appreciate your compliments
As for your question, my setup was on stock cooling at 3.0ghz, and I didn't put on the Ultra 120 until after I tested load at 3.2ghz.
I have temp recordings that I can post as charts for comparison, if you think that might be valuable information. The environment is controlled for, as ambient was always the same (20 celsius) and the fans were always on the same setting.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Reviewer Tryouts: XFX 8800GT Extreme Zertz Member Reviews 0 December 2, 2007 02:35 AM
Reviewer Tryouts: Mushkin 4GB HP2-6400 Eldonko Member Reviews 3 November 30, 2007 08:31 PM
Reviewer Tryouts: Scythe SFF21F AkG Member Reviews 4 November 7, 2007 09:08 AM
Reviewer Tryouts: OCZ SD 150x card AkG Member Reviews 4 October 24, 2007 01:38 PM
