  #21 (permalink)
Old February 20, 2010, 10:47 AM
martin_metal_88's Avatar
Great review ST! you should do it more often with different fan and different use like the best for rad etc! Awesome again we like to have you here my friend
  #22 (permalink)
Old February 20, 2010, 10:50 AM
Soultribunal's Avatar
Thank you. As I have time in my life I intend to do a lot of reviews, including smaller and Larger Fans as I get the Heatsinks to use and Test them on.
Once I have a Good WC Setup (Corsair H50 comes to mind) I will do that as well. It comes down to time and Money for me lol.
ST
www.realhardwarereviews.com
  #23 (permalink)
Old February 20, 2010, 10:56 AM
ST
Great to heat that fom you!
  #24 (permalink)
Old February 20, 2010, 06:51 PM
Updated with proper Graphs. I'll fix the Pictures so they end up a little smaller.
This after all is a work in progress to get a proper setup to do fan reviews.
ST
  #25 (permalink)
Old February 20, 2010, 06:55 PM
shaw
Guest
Posts: n/a
Pics show as Red Xs now.
I do have a question: you mention in the opening paragraph that you will test "case" fans, but your testing rig setup and results are from a HSF. Don't fans have a different behavior (read performance) when used for intake/exhaust, HSF use and to an extent Radiator fans?
  #26 (permalink)
Old February 20, 2010, 07:04 PM
Re-Sizing the Pictures.
Case Fan is really a Mis-nomer description. Realistically it should read "Cooling Fan" as they are used in various applications and Situations. Yes Fans do very much have different sounds (See Noise) and behaviours Depending entirelly on the situation used.
To the best of my abilities, and lacking each individual Heatsink , Radiator out there I seek to give simple guildlines. At no point are my results , Views, or Situations to be taken as an Absolute.
Best Regards,
ST
Tags
coolermaster , fan review , gelid , silenx , yate loon
Low Cost - High Performance? TokeR New Builds 18 February 8, 2010 06:22 AM
Corsair Adds TX950W High Performance Power Supply FiXT Press Releases & Tech News 1 October 6, 2009 11:13 AM
[FS] BNIB High End Radiator 240 TFC **High Performance** qaz393 Buy/Sell & Trade 4 August 17, 2009 01:47 PM
Corsair Launches New Extreme Series High-Performance SSDs FiXT Press Releases & Tech News 0 July 16, 2009 11:05 AM
