Sandra Memory Bandwidth -24517 MB/s
EVEREST Memory Read -18357 MB/s
P55-GD80 has a great performance on the voltage ratio under the 200/2000 settings.
This time, msi overclocking feature gives me a brand new feeling.
Compare to the experience of using mainboards of msi,
there were always some minor problems or the overclocking performance of the memory wasn’t as good as other brands.
However, P55-GD80 has no above problems which I mentioned. It went smoothly when I adjusted the bios setting.
Also, like other mainboard manufacturers, it shows a great overclocking performance.
Finally, we adjust the CPU frequency to 210/2100
CPU 210.5 X 20 => 4209MHz
DDR3 2105 CL9 9-9-24
OS settings
Hyper 4 X PI 32M=> 9m 28.823s
CPUMARK 99=> 651
Nuclearus Multi Core => 7977/11893/33234
Fritz Chess Benchmark => 20.54/12362
CrystalMark 2004R3
CINEBENCH R10
1 CPU=> 5950
x CPU=> 21514
Sandra Memory Bandwidth -25789 MB/s
EVEREST Memory Read -19136 MB/s
The 210/2100 CPU frequency setting brings the CPU frequency up to 4.2GHz, so the parameter of CPU/Dram/VTT voltage is higher.
Finally, there was no problem during the test.
Besides the overclocking ability of the mainboard,
the quality of the CPU and memory is one of the important factors,
MSI P55-GD80 passed many tests under the condition of 210/2100 frequency setting,
which proves the overclocking ability and stability of MSI P55-GD80.
MSI P55-GD80
Advantages
1.MSI P55-GD80 has many innovative features, like Direct OC/V-Kit/Easy Button…,and etc.
2.Embed with OC Genie auto OC chip. Press OC Genie button and we can get an excellent overclocking performance.
3.Three PCI-E X16 and support ATI CrossFireX and Nvidia SLI Tech.
4.With all Japanese solid capacitors, 8mm super pipe and easy Power/Reset bottoms
5.Use DrMOS to save power. The Control Center software is very user-friendly.
6.Excellent BIOS design with high adjustable voltage range and great CPU/DDR3 overclocking ability.
Disadvantages
1.The carton design should be improved because P55-GD80 is a high-end product.
2.Currently, on the market there is not much demand on P55 chipset mainboard’s price is higher than 200 USD.
If we use the OC Genie function, the voltage will be a little bit high.
Performances ★★★★★★★★★☆
Materials ★★★★★★★★★☆
Specifications ★★★★★★★★☆☆
Externals ★★★★★★★★☆☆
C/P Value ★★★★★★★☆☆☆
Sometimes I feel the trend of the market development is quite strange.
It seems that there is a tendency that manufacturers like to have a competition,
which especially focus on the components of the mainboards.
Each manufacturer adds more functions and creates new features on the mainboard, so that the price is getting higher and higher.
If the price of the P55 product is more than 300 USD, I doubt if the consumer will buy it
In my opinion, if you want to use Intel CPU as your platform and you are already an owner of LGA 775,
it will be more cost-effective. You can just upgrade your CPU. For example, Q8400 or Q9550.
However, if you would like to buy a new platform and you have enough budget,
Intel Core i5-750 with 155~200USD mainboard will be a better choice. The C/P value is much higher.
Finally, if you have sufficient budget, using the LGA 1366 platform is also a good choice for upgrading Intel i9 in the future.
For me, I can strongly feel that MSI has great improvement on its new product quality and the selections of the components.
No matter the software, overclocking features or the components on the MSI P55 mainboard make me feel impressive,
especially the stability of the BIOS.
Intel has released the P55 chipset recently, and it is defined as a middle-end product.
Currently, the price is approximately 155~280USD.
Within this price range, the P55 product is also divided into three classes, which are high-end products,
middle-end products, and low-end products. Comparing to the P55 high-end product in the market, MSI P55 is much more cost-effective.
This is one of the reasons that MSI deserves so much praise.
Although the quality of MSI P55 mainboard is excellent, I still hope they can maintain the cost-effective price strategy,
so that the users who don’t have a lot of budget still can buy a mainboard with excellent performance and innovative features.
