| Welcome to the forums BTW I speak in gibberish, just a heads up.
__________________ Rocket Surgery-A Combination of Rocket Science & Brain Surgery Nothing in Moderation Problems with your DC Order? PM Direct Canada's Forum Rep |
Hi, just thought I would add that I have this cooler, and in my Antec Sonata III case the 120mm fan is also in that spot, but only about 2cm away from the edge of the s1 cooler. I also have the "Turbo module" that is 2x80mm (I think) shroudless fans that clip on to the fins. I recommend the Turbo Module as it is only 7 bucks more and takes about 2 seconds to install. On my x1950pro with stock cooler I got 50*C idle and 80*C after running 3d06. With the s1 I get 28*C idle and 37*C load!!!! These temps are so low I think its a glitch in rivatuner... and it is SILENT, cant hear it unless you get your ear so close the shoudless blades cut your ear off...
__________________ My komPuter - Mobo P35-DS3L rev2 CPU e6750@3.2GHz CPU Cooler: TRUE w/2xNF-SP12's RAM:2x1GB Ballistix@800 GPU:x1950pro GPU cooler :AC Accelero S1 Case: Antec 900 PS: Antec SP-500 Monitor:Samsung 931c |
| Quote:
__________________ CSE: Lian-Li PC-A70 MOB: Biostar T-Power I45 CPU: Intel C2D E8600 @ 4.3ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w Heatware: My Heatware |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Accelero S1 - Stock TIM or AS5 ? | mattydies | Air Cooling | 3 | February 14, 2008 09:27 PM |
| Accelero S1 on 8800GT | Hitikiro | Air Cooling | 8 | December 17, 2007 08:53 PM |
| HD 2600xt + accelero s1/2? | nikitos | Video Cards | 2 | December 17, 2007 05:08 PM |
| Arctic Cooling Accelero Xtreme | Kopi | Rumor Mill | 5 | November 28, 2007 10:19 AM |
