Old September 4, 2009, 05:09 PM
FreeKnight's Avatar
Default Scythe Mugen 2 CPU Cooler Review
Hey Everyone,
Just put a Scythe Mugen II cooler on my i7 system and since we don't have a review for it on the site, I thought I'd throw in my thoughts.
- Initial Thoughts -
I had heard good things about the Mugen II cooler, and it's advertised as 1366 compatible. The cooler itself looks and feels well made and has ample cooling fins and heatpipes. The kit also includes a Scythe fan, and more can be installed on the cooler.
- Installation -
Wow, this is worse than Ikea instructions. Open up the box and you'll find about half a dozen mounting plates, arms, etc. Included are a bunch of bushings, screws and a small pack of thermal paste.
My first gripe upon looking at the instructions was how they tried to do a universal manual using mostly pictures and some text in about 8 languages. The pictures can be very ambiguous however and the text is nearly useless. About the only way the instructions could be less vague would be to say 'Put that thing over there, on that spot where it's supposed to go'.
It could just be my motherboard, but the directions for the 1366 mounting plate didn't match the holes on my board at all. After a bit of playing around I found I could get it to mount using the Q series mount combined with the 1366 brackets, but it was a pain figuring it out on my own.
Once fastned properly however, the cooler fits quite nice. The vertical clearance over my memory slots was a bit close. Fortunately my OCZ platinum doesn't have any additional heatspreaders on the top, but those of you using mem like G.Skill and Dominator might have clearance issues with your fan.
Speaking of the fan, it mounts fairly easily once you figure out how (thanks to the terrible instructions again). It uses two thin wire torsion clips to hold it the the cooler. A very nice feature is that you can pretty much arrange the cooler and fan in any direction/orientation you want. I have mine set up blowing cold air from below through the heatsink upwards towards the top exhaust of my case.
-Performance-
I haven't run benchmarks on this yet. But so far I've been really impressed with the cooling of this unit. Realtemp is usually showing in the high 30s or very low 40s with this on in idle to moderate use. Obviously running at load it's hotter, but so far I don't think I've broken the low 50s. Once I run some thorough tests I'll update this thread, but as of now, I'm pretty happy. The coolers' square shape and smaller size meant it fits in my case no problem and I didn't have to worry about the clearance issues of a TRUE or the Megahalems.
-Overall-
Pros
-Quiet (like a ninja!)
-Good Cooling
- Fan included
- Good Price, usually 30 bucks cheaper than a TRUE (or was when I was looking)
Cons
-Worst... Instructions.... Ever....
-Might not have the cooling potential of larger units
-Mounting brackets and clips don't necessarily mount how they say they're supposed to.
Overall I'm fairly content with this cooler. I was worried a TRUE or Megahalems wouldn't fit, so I decided to play it safe with this unit. It's quiet and cools pretty well. The included fan is high quality and clears normal sized memory. For a first time build though, I don't know if I'd recommend it for someone who wasn't confident in their problem solving skills. The instructions are terrible, and they give you just enough bushings and washers to squeak by, so don't loose any.
Now that my system is together and I'm looking at overclocking, I'll probably replace it with a CM Hyper 212+ or a Megahalems in the future though.
As always, your 2 cents are welcome. Post away
Old September 4, 2009, 10:17 PM
jcmaz's Avatar
Nice review, but do you have any pictures.
btw, why didn't you go with the Coolermaster 212+?
-Plato
Old September 5, 2009, 05:31 PM
FreeKnight's Avatar
Thanks. I was working out of town and only had one day off in Edmonton, so I had to go with what I could get at mem express. I couldn't get stuff mailed to the town I was working out of and wasn't sure when I'd get another weekend off.
Had I been based out of town, I'd have waited for the 212+ though. It's supposed to be a better all around cooler. Though if I ever overclock this cpu, I'll get the 212+ or a Megahalems.
I should have some pics I can put up soon.
My System - Mimir
|- Intel i7 920 -| - Corsair 850w HX Modular PSU -|- Gigabyte G1. Sniper -|- 24GB Corsair Vengeance DDR3 -|- Prolimatech Megashadow Cooler -|
- EVGA GTX 670 FTW -|-2x Crucial M4 256GB RAID 0-|- Seagate Barracuda 3TB -|- WD Caviar Green 2TB HDD -|- Corsair 600T White -|- Windows 7 Ultimate -|
Old September 5, 2009, 08:09 PM
rapmaster's Avatar
I'm not sure, but I think the Mugen 2 give more performance than the 212+. The mugen 2 equal an unlapped TRUE.
Quando omni flunkus moritati
Old September 5, 2009, 10:03 PM
I don't mean to tread on anybody but i thought i would add a little here. Hope you don't mind.
Late July i built a new i7 rig for my younger brother and purchased a mugen 2 for it.
I will admit the instructions are practically useless on one hand, but after filing them and doing a little googling with a few minutes of thought, it's relatively straight forward if not a little awkward.
Peronally i was happy with the outcome myself, not to go against the huge fanbase the 212+ has here but IMO it is slightly better at cooling... give or take.
Just a few pics now...
Antec 300 with a P6T SE and i7 920, for ambient temps ( 26.7 c ) i left the air off because i wanted to stress the system further. One thing to note is the choice of RAM, the larger RAM sinks can get in the way, although with the 300's side intake being aligned nearly by design with a bottom mount fan and the dual slot 4850 that was not a significant problem for me. OK enough babbling, Stock and O/C temps, HT was left on throughout.
Here is how the side intake fan lines up.
Overall i think it looks good and does and does a good job.
Old September 5, 2009, 11:27 PM
O.o.. that things really big man, I thought it was some modded heatsink, couple of them attached together..
Old September 7, 2009, 06:13 AM
TopDogZero's Avatar
Is HWC going to review this at some point?
Old September 7, 2009, 08:49 AM
Methinks the only one in existence was bought by traitoR. That cooler is huge!
System Spec Peripherals: Corsair H70 cpu cooler (w/ 2 120mm Scythe Gentle Typhoon 1850rpm fans) | Zalman MFC3 fan controller | Gigabyte Aivia Osmium kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakers | SteelSeries SX mouse surface
For the real serious stuff: 2.53GHz Mac Mini | 4GB DDR3 1066 RAM | 320GB HDD | Samsung P2250 (x2) | Apple Magic Mouse | Apple Magic Trackpad | Apple Wireless KB | Drobo FS 6.5TB
Laptops: Dell XPS M1530 | Asus G74SX-DH71
Surface Pro 128GB
Old September 7, 2009, 12:06 PM
When i received it i compared it to my Ultima 90, which is like a childs toy compared to it, to think i thought that was big at one time. It's really reasonable price wise, the base is like a mirror finish on it as well.
Old September 7, 2009, 07:43 PM
ToXic's Avatar
Christ on a cracker.... shes a monster... makes the Xtinguisher look like a passive...
Thermalright IFX-14 Inferno Fire eXtinguisher CPU Cooler at Memory Express Computers
Some kind of pathetic Apple convert
17" Macbook Pro (early 2011 model)
2.2Ghz i7-2720QM | 8GB Corsair DDR3 1333Mhz | 750gb Toshiba HDD | ATI 6750M 1GB
Scythe Mugen 2 - Temps high? MittWaffle Air Cooling 2 July 25, 2009 03:38 AM
[FS] Q6600 w/ Scythe Mugen, eVGA 750i FTW, 2GB Corsair, G15, G25 wonton1017 Buy/Sell & Trade 14 July 17, 2009 01:48 AM
Scythe Introduces Kama Angle CPU Cooler MAC Press Releases & Tech News 4 October 27, 2008 12:46 PM
Scythe Announces Ninja 2 CPU Cooler MAC Press Releases & Tech News 1 July 14, 2008 12:03 PM
