Originally Posted by bojangles Hey Darkstar I'll sell you my 36" CRT TV if you don't like LCD so much. I am making the switch to LCD. |
I have no need for it - thanks - I already have TV CRTs, and 2 flatscreen PC monitors (CRTs) One a Samsung and another a Viewsonic Professional Series - Once those 2 CRTs go bad I will have no choice.
What you don't understand is that you don't need the perfect LCD monitor to do simple things like Office apps, surfing the web and other small things. You do,
lol - exactly - Even a cheap crap TN panel is quite suffice. THat's the point - I don't use my computer for ONLY that, and by the type of members here, I'm sure most don't either - I use it for gaming, I use it for work, I do a lot of video editing, authoring, graphics work, color correction, etc......
however, need an LCD monitor that has a high colour gamut for image editing and detailed work. You don't need a TV with a high colour gamut to watch movies and games because the colours are always changing on every frame.
Problem is - a computer monitor with higher gammut costs you speed, are not good for gaming - and those that have low latency are bad for graphics and color accuracy - you can't get both.
Then there is the issue of native resolution on LCD - anything outside native = blurry crap.
If you really are that picky then you better take good care of that CRT, because it'll eventually burn out, just like any electronic device. I've been really happy with my
You would be surprised at how long some of my CRTs have lasted - I hand pick them when I buy - I don't buy just any cheap model. The CRTs don't really "BURN OUT", most of the failures of CRT are power related (flyback transformers, power supply, alignments, etc.....) and CAN be repaired, but most people don't bother because of cost anyways......... It's not fair to have a GOOD graphics card and a monitor that DITHERS tos imulate 24bit, that's what's done on TN panels, if I go with IPS, I would get true 16.7, but high latency not suitable for gaming.
Samsung 226BW even though it's a TN panel. YES, you don't get the greatest viewing angles and 100% of the colour gamut, but what you do get is great little monitor that can play games with great colour quality at a great price. I spend my time in front of the monitor, not the side, and the 2ms is just a marketing gimmick. I'd be just as happy with 5ms or 8ms because the ghosting problem has been reduced substantially over the years.
Substancially but not completly - it's still there..... the 2ms, etc, all GIMMICKS indeed, most people don't know a thing about how LCD work and what is Gray-to-Gray, etc. so they say WOW 2ms WOW! :D
The only thing that could have really replaced CRT is SED......Maybe one of those days multi-LED LCDs will replace current single backlight and it will be a step higher than current LCDs......... Samsungs new TV LCD with multiled sure rivals any CRT for TV viewing - but I don't have $6000 to spend on a bloody TV! LOL I hope eventually to see computer monitors like that in the $1000 range.
