Old May 7, 2009, 08:12 PM
Eagle Eye's Avatar
asus p6t mb
asus 4870 1 gb gpu
17 920 cpu this time oclockable
1tb segate 7200 rpm hd
cooling by thermalite
850w psu
Silverstone Temjin TJ09 ATX Case
vista home premium 64 bit
Pretty solid platform, assuming "thermalite" is ThermalRight?
Don't see any memory?
Not bringing up the Seagate issue(s), in my opinion a Western Digital or Samsung drive would be a better choice.
850w PSU...Which brand?
Case...Great choice!!
Just my opinion, hopefully the more experienced can chime in on recommendations.
Regards,
EE
Old May 7, 2009, 09:31 PM
TimTheEnchanter's Avatar
Originally Posted by snafup View Post
hi all returned the gateway slug.
heres my order list let me know what you think
asus p6t mb
asus 4870 1 gb gpu
850w psu
asus 4870? i don't know about their warranty, but i suppose HIS or XFX would be better?
+1 for wester digital HDD
be more precise for the cooling
if there is some good ram, i suppose it should be a pretty good build.
Old May 8, 2009, 10:08 AM
Default new build
hi sorrry for the vagueness
memory
6gb corsair xms3 classic 1333 mhz
thermaright ultra 720 extreme
antec tpq 850 true power quattro psu
Old May 10, 2009, 10:38 AM
That TPQ 850 is overkill for your build. If your cash flow isn't an issue, then by all means buy it. It'll serve you well and give your system a bit of futureproofing. If you're in a bit of a budget crunch, go with a less powerful Corsair unit.
Old May 10, 2009, 01:31 PM
b1lk1's Avatar
I wouldn't touch a TPQ 850W Antec with a 5000' pole. Corsair all the way.
MY HEATWARE
Old May 10, 2009, 02:21 PM
3 of 7's Avatar
How do the costs of the 2 systems compare?
Nature always sides with the hidden flaw
Old May 10, 2009, 03:44 PM
Default price diff
the gateway cost 1640 with taxes
the build cost 2100 with taxes
Old May 11, 2009, 05:34 PM
asus p6t mb
asus 4870 1 gb gpu
850w psu
Well I am currently working on a system, and so far I have a TJ04B, a pair of 1TB WD Caviar Blacks, and a 610W PCP&C Silencer. I figure the 920 and a P6T is a good choice. I will absolutely use an nvidia card though. ATI is still in my "bad company" book for their many years of crappy support. Seagate seems to have had a lot of firmware issues over the last few years. Not something I want to put up with either.
Len Sorensen
  #19 (permalink)
Old August 2, 2009, 03:08 PM
Airshehan's Avatar
This is why I personally don`t like Gateway! You should talk to the CostCo Customer support! If they aren`t any help, return it and get another system! Always remember to do your research!
Dell XPS 630i / Intel Core 2 Quad Q9300 @ 2.67GHz / Stock Cooling (Temporary) / 6GB DDR2 800 RAM + 4GB Windows ReadyBoost/ Nvidia GeForce 9800 GT / Samsung SpinPoint 640GB + Seagate FreeAgent 250GB / 750W PSU / Nvidia Nforce 650i SLI / Logitech X-235 Speakers + Plantronics .Audio 370 Gaming Headset / Dell 22' E228WFP / Razer DeathAdder /Windows Vista Home Premium 64-Bit
Airshehan
Gateway XHD3000 belgolas Display Units 3 March 16, 2009 07:56 PM
Gateway P-7811 FX Natamanchuk Mobile Computing 9 October 3, 2008 02:31 PM
