Old April 16, 2009, 07:32 PM
stoanee's Avatar
Default Scythe Musashi VGA cooler review
Scythe Musashi VGA Cooler Review
Review by Darryll “stoanee” Johnstone
Date; April 16/09
Manufacturers product page-Scythe Musashi
Product name-MUSASHI VGA Cooler
Model no.-SCVMS-1000
Prices-click here!
Introduction
Here we have a first offering VGA cooler from Scythe that is named after a Japanese swordsman who lived until 1580. Scythe is well known for their cpu coolers, fans and other computer equipment. Miyamoto Musashi is well known in Japan and was renowned for his distinctive style and his excellent swordsmanship. Can his namesake cooler match his reputation? Read on and we will find out.
Features
(from Scythe website)
-This product is compatible for wide variety of graphic cards, for ATI Radeon 9000 to HD4800 class, and for nVIDIA GeForce FX5900 to 9600 class.
-Dual Independent Fan with Controller
-Equipped with dual Scythe original super thin "“Kaze Jyu Slim 100mm" fan, users can independently control each fan speed to fulfill the demand for silent to over-clocking purposes.
-Optional Single Fan Mode
-Single fan mode can be arranged by simply detaching 1 fan and place another fan onto the middle of the VGA cooler to intensively cool the GPU.
-Air-Through Construction
Airflow can be directed to the entire graphic card to ensure the complete cooling of the graphic card.
-Various Memory Heat sinks Included
-In order to maximize the cooling performance, the various memory heatsinks (chips) are included in the package.
Specifications
Model Name: MUSASHI VGA Cooler Model Number: SCVMS-1000
Manufacturer: Scythe Co., Ltd. Japan
Overall Dimension (W x D x Thickness): 104 x 250 x 35 mm 4.09 x 9.84 x 1.38 in Weight: 375 g 12.1 oz
Heatsink Dimension (W x D x Thickness): 104 x 250 x 35 mm 4.09 x 9.84 x 1.38 in Weight: 251 g 8.8 oz
Fan Dimension (W x D x Thickness): 100 x 100 x 12 mm 3.94 x 3.94 x 0.47 in Speed: 800 ~ 2000 rpm
Noise: 12.50 ~ 29.22dBA
Flow: 11.45 ~ 27.60CFM
Bearing Type-Sleeve Bearing
Fitment
Radeon X***
Radeon X1300
Radeon X1600
Radeon X1650
Radeon X1800
Radeon X1900
Radeon X1950
Radeon HD2600
Radeon HD2900 XT
Radeon HD3650
Radeon HD3850
Radeon HD3870
Radeon HD4850
Radeon HD4870
GeForce FX5900
GeForce 6600
GeForce 6800
GeForce 7300
GeForce 7600
GeForce 7800
GeForce 7900
GeForce 8500
GeForce 8600
GeForce 8800 GT
GeForce 8800 GTS
GeForce 9600
GeForce 9800 GTX
Includes
-Cooler complete with attached fans
-Fan controller for both fans
-Back plate and mounting studs
-Various heatsinks
-4 pin to 3 pin adaptor
-TIM
Packaging and Accessories
I purchased this from my local Memory Express retailer and as you can see the box was chock full of pictures and printing, both in English and Japanese. Good pictures of the cooler and all the various graphics cards it is designed for were listed on the box. The contents were all protected by cardboard that enveloped the cooler; first the contents slide out then there is a flap folded over the cooler. Everything was in good shape so the packaging seems to be effective.
Name:  2.Mushashi rear box.JPG
Name:  3.Musashi slid out of box resized.JPG
Name:  4.Musashi out of box.JPG
Name:  5.Musashi on box resized.JPG
Once out of the box you find the cooler, instructions, a bag of parts containing the mounting hardware, heatsinks and some TIM. Note that the fan controller is permanently wired in to the fans, if you do not want to use it you will have to test out your wiring skills to remove it. This controller allows the fans to run between 800-2000rpm giving 12-28 CFM airflow per fan and mounts in a slot at the back of your case.
Name:  6.Musashi out of box all resized.JPG
Upon closer inspection, you can see that just about the entire surface of the cooler is covered by the two included fans. One thing I noticed while handling this cooler is the fins are very thin and easily bent. Careful handling and no dropping are the rules of the day when installing this cooler.
Name:  7.Musashi up close resized.JPG
Looking at it from the side you can see that the fans are very thin at 12mm and the two 6mm heatpipes run the length of the cooler. The total thickness of this cooler is 35mm which is 3mm wider than the stock 4870 cooler it is replacing. Depending which motherboard you have you should still be able to run Crossfire if desired.
Name:  8.Musashi side view resized.JPG
Flipping the cooler over, you can see the two heatpipes that run in opposite directions, one with a longer run than the other. The heatpipes terminate with chromed caps that give a nice finished look. Most of the competitions vga coolers have four heatpipes that spread out and then run across the width of the cooler.
Name:  9.rear unpacked resized.JPG
The heatsink surface is nicely finished and is almost flat, dropping off in the four corners to make it slightly convex.
Name:  10. Close up of heatsink resized.JPG
The next step is to remove the stock cooler from my 4870 and prepare to mount the Musashi in its place.
Name:  11. Stock cooler resized.JPG
Remove the ten screws that hold the cooler/fan body on the card and then the four screws and back plate that hold the gpu cooler in place. Once this is done it all comes off without any issues.
Name:  12.Rear of vid card resized.JPG
The pink strips and the white strip are thermal pads that play an important part in cooling the voltage regulators etc. They maintain contact with the red cooler body, various chips and transfer their heat to it to be dissipated by the fan.
Name:  13.Stock cooler removed resized.JPG
Here is a HIS 4870 in its naked glory, you can see some gunk lodged on various chips; everything must be squeaky clean prior to the Musashi install.
Name:  14.Naked card resized.JPG
Next I mocked up the new cooler to the card to check for clearance, I have plenty of room but I still need to mount the heatsinks then recheck the clearances. In this view you can see the side detail of the aluminum heat sink that is directly above the cooler base.
Name:  15.Side mock up resized.JPG
When you unpack the mounting kit it becomes apparent that you have more heatsinks than you will need as this is a “one size fits all” style of cooler. I surfed around the internet as well as used the instructions to decide where to best apply the heatsinks. The four mounting posts complete with circular nuts can be seen, the backplate, also a copper spacer to be used to gain additional clearance between the cooler and the card if needed. TIM is also supplied.
Name:  16.Heatsinks resized.JPG
I cleaned off the surface of the chips with 99% alcohol, peeled off the thermal tape backing and firmly pressed on the heatsinks. Once in place they all stayed put without any issues.
Name:  17.Heatsinks applied resized.JPG
I again mocked up the cooler, clearances were fine, and I did not need to use the copper spacer that comes with the kit
Name:  18.Heatsink clearance resized.JPG
Next you need to flip over the cooler and thread the mounting posts into the corresponding holes that align with you particular card and position your card onto the cooler. In this instance I used Arctic Cooling MX-2 TIM to mount it with.
Name:  19.Posts mounted resized.JPG
One thing you can see here is the clearance around the mounting studs through the holes in the card itself. This unfortunately allows some movement of the cooler on the card; it will wiggle back and forth.
Name:  20.Posts through board resized.JPG
The back plate goes on with the rubber pad against the PCB, followed by the circular nuts.
Name:  21.Backplate resized.JPG
As I mentioned above there was some movement due to the clearance between the card holes and the diameter of the studs, so I put washers under the nuts to hold the cooler on tighter. This did help, but you can still move the cooler on the card.
Name:  22.Backplate mounted resized.JPG
Here is a shot with the fans removed to show the fitment on the card. Just a note here, the fan mounting brackets fit into slots on the fins, and due to the thinness of these fins you must be very careful when removing or installing fans. The fins bend very easily and the potential is there to mess these up. Note the aluminum heatsink directly above the base.You can see the cooler is longer than the card by 25mm to the polished cap at the end of the heatpipes. You have to check your case beforehand for clearance.
Name:  23.Mounted with fans off resized..JPG
Here is a shot of the fans in their stock location, note the gap between the fans and over the heat sinks, this caused cooling problems for me when stress testing this setup, more on that later.
Name:  24.Fan shot resized.JPG
Testing
Once finished, I put the reconfigured card into my rig and began testing the card. The test rig is as follows;
  • Intel Q9450 Processor
  • Asus P5Q Deluxe Motherboard
  • Mushkin XP PC2-8000 Redline 2 x 2 GB
  • PC Power and Cooling Silencer 750 Quad PSU
  • HIS Radeon 4870 GPU
  • Top Deck Tech Station
  • Arctic Cooling MX-2 High Performance Thermal Compound
I used OCCT version 3.0.1 to give the 4870 a workout for an hour and to record temperatures. The first test was with the stock cooler at an ambient temp of 18C, you can see it idled at 45-46C and topped out at 80-82C. The fan ramped up to about 50% and was noticeably loud.
After the install of the Musashi I tried to run the same test but the card kept locking up with an ominous red LED glowing on the back of the card. Research proved this to be the D601 LED warning of critical component overheating.
Remember the gap between the fans? I suspected that the heat sinks on the chips were not getting enough air over them but the fans could only be moved slightly sideways which did not help, the card kept locking up under testing. I had both Scythe 100mm fans running at top speed but it was not enough to cool the heat sinks affixed to the components on the card. Unfortunately replacing the included 100mm fans for something more robust would not be very easily done due to the style of the fan clips and the fragility of the fins. A good thing about the Scythe fans is that they are much quieter than the stock fan and can be tailored to your cooling requirements with the fan controller.
In an attempt to isolate the lockup problem I clamped an 80mm Scythe fan to the side of the tech station pointing at the videocard and tried testing again. I ran the same test for an hour without lockups so airflow was definitely the culprit.
Finally after some head scratching I ran my finger on the back of the videocard while under load and made note of any hotspots that I felt. I put more heatsinks on any chips that were associated with these higher temperatures and basically anything else I could stick a heatsink on. I removed the 80mm fan from the tech station and tried testing again. With these added heatsinks on the card would complete the tests underscoring the importance of having lots of heatsinks in the right places.
Here the idle temps are 32-33C for a drop of 13C+- and load temps of 57-58C for a drop of 25C+-.
Conclusion
The Scythe Musashi, on this 4870, does a good job of cooling the gpu and an adequate job of cooling the card components. I think if you tried to overclock this card you may run into problems with this cooler but it may take something as simple as judicious use of aftermarket copper heatsinks to overcome component overheating. If you are looking for a quieter cooling solution for your graphics card and lower temperatures, then this cooler works well. If you are looking for a heavy duty solution for overclocking you may have some tweaking in store for you.
The GPU cooler itself works very well as you can see by the 25C temperature reduction, but it is unfortunate that the fans cannot be easily upgraded. In my opinion a little more airflow is needed and would really make this cooler shine. Also, one problem with this style of cooler is that all the heated air is no longer exhausted out the back of the card, but will stay inside your case so you will need good case cooling.
Pros
-Easy to mount on a variety of video cards
-Provides better cooling than stock coolers under moderate use
-Quieter than stock coolers
-Competitive pricing
-Fan controller is included
-Extra heatsinks provided
Cons
-Difficult to use any fans other than what is provided.
-Loose fit on video card due to clearances between mounting holes and studs.
-Fins are thin and easily bent.
-Instructions are sketchy concerning heatsink placement
-Heat from the cooler is exhausted into the computer case.
As it stands the Scythe Musashi cooler delivers on its performance and noise reduction promises and I give this my recommendation.
heatware
Old April 17, 2009, 05:27 AM
Soultribunal's Avatar
Excellent Review my friend, looks like a decent cooler for sure. :)
ST
Old May 14, 2009, 02:12 PM
Good review! Your pictures were an inspiration to do a better job on my next one. Excellent close ups!
I have this exact 4870, though I don't see the need to purchase this product. Mine is overclocked, and I just turn up the fans to 100% and turn up the volume on my speakers when I'm gaming :)
Old May 14, 2009, 02:50 PM
FiXT's Avatar
Hall of Fame
Excellent review!
A buddy of mine was looking for an aftermarket cooler for his 4870 - This sounds to be a perfect solution!
Great images as well!
One suggestion in case you do a future review. Feel free to put 2 images beside each other or stack 4 of them so you can have a larger amount of descriptive text for images that show similar things :D
Use the Zoom feature around your small image, which points to your large image :D
Old May 14, 2009, 04:00 PM
stoanee's Avatar
Hmm...when I view this today not all the pictures are showing. Is it the same for you? Also i do not know how to use the "zoom feature"
heatware
Old May 17, 2009, 02:30 PM
same her... fix that loll, im realy interesting seeing all picture(i have the same card and check for a cooler)
Old May 17, 2009, 06:05 PM
Yoda8232's Avatar
Dang looks beastly, nice review.
Old May 18, 2009, 08:37 AM
someguyfromhell's Avatar
Nice review, great pictures.
Specs: C2Q Q9550 @ 3.5Ghz, Asus P5Q Deluxe, G.SKILL F2-8500CL5D-4GBPK, Sapphire Radeon 4890, Cooler Master Silent Pro 700w PSU, WD Caviar Black 640GB, Hitachi 2TB HDD, Windows 7 64bit
Old May 18, 2009, 10:23 AM
misterlarry's Avatar
Great review stoanee. Just curious though, wth is "fitment" and is that a real word anywhere other than the Scythe website? Very good work!
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old May 18, 2009, 12:56 PM
stoanee's Avatar
Oh snap! Should have used a noun with it as in "video card fitment" (Noun used with modifier)
When I get home from work (2 weeks), I will edit and reload the missing pictures, not sure what happened to them.
heatware
[WTB] VGA cooler for a 4870 Flintblade Buy/Sell & Trade 0 March 13, 2009 12:27 PM
Massive new Scythe cooler?! Cptn Vortex Press Releases & Tech News 26 March 3, 2008 04:43 PM
Massive Scythe Cooler, among others. Cptn Vortex Rumor Mill 8 November 29, 2007 01:11 PM
