Old May 28, 2007, 03:00 PM
Wankerfx's Avatar
Default OCZ Reaper PN – OCZ2RPR8002GK Review
Index:
1. Introduction
2. First Impressions
3. Setup
4. Testing
5. Conclusion
1. Introduction:
OCZ first entered the memory market in the year 2000. They have been the primary source of memory for overclockers for more than 7 years and continue to amaze consumers with their innovative products. OCZ has introduced the new “Reaper” series with its ground-breaking HPC (Heat Pipe Conduit) technology.
Today I’ll be testing the entry level modules of the “Reaper” series; the PN – OCZ2RPR8002GK.
Model Name: PN – OCZ2RPR8002GK
Speed: DDR2-800, 4-4-4-15, 2.1V
PCB: Unknown
Size: 2 x 1GB
Warranty: Lifetime (Up to 2.2V)
This kit is available for Canadians at a mediocre price of 219.99 CAD after the mail-in rebate: http://www.ncix.com/products/index.p...Z%20Technology
This kit is available for Americans at a low price of 129.99 USD after the mail-in rebate: Newegg.com - OCZ Reaper HPC Edition 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
2. First Impressions:
The ram was concealed in a tough, plastic container. It had a cardboard insert behind the ram, advertising its HPC technology, and warranty information. The ram heatsinks must be the most aggressive looking things I have ever seen! Each side of the module has a thick piece of alloy which is connected to an oval copper tube, leading up to another small heatsink.
The modules weigh quite a bit, so be careful not to drop them onto your toes! Another thing to be aware of is installation; be sure to install the modules slowly, or risk cutting yourself on the top part of the heatsink.
In total, I give the PN – OCZ2RPR8002GK’s 10/10 for visuals. The packaging was ordinary; but the actual ram heatsinks added flavor to the whole kit. I have to mention that I have never seen something so beastly in all my years of computing. Now that we have all the physical features down, let’s get into the juicy stuff!
3. Setup:
Motherboard: Asus P5B-Deluxe WiFi
CPU: Intel E6300 (L626A)
CPU Cooling: Tuniq Tower 120
GPU: Asus EN7900GTX
PSU: OCZ GXS 700 watt
HD: Western Digital Caviar (250gb)
OS: Windows XP
4. Testing:
I will be using dual SuperPI 32M to test the stability of these modules when overclocking. It’s a good way to establish whether the overclocked speed is stable or not. Using dual SuperPi 32M is by no means an easy route to testing a 24/7 stable computer. I will be doing an 8 hour orthos test, running within OCZ’s warranty (2.2V). All speeds recorded are over DDR2-800 and the modules were tested with memtest86 prior to the overclocking to make sure they weren’t defective.
The Reapers work with no struggle at their advertised speeds:
Name:  DDR2-800, 4-4-4-15, 210V.jpg
CL3:
I attempted to test the speed of DDR2-800, 3-3-3-8 with volts 2.25-2.45 and received no sign of stability. (Didn’t even boot into windows)
CL4:
DDR2-825, 4-4-4-12 was accomplished with 2.25V:
Name:  DDR2-825, 4-4-4-12, 225V.jpg
DDR2-861, 4-4-4-12 was accomplished with 2.35V
Name:  DDR2-861, 4-4-4-12. 235V.jpg
Sadly, adding more voltage decreased the stability of these modules. (Past 2.35V)
CL5:
DDR2-921, 5-5-5-15 was achieved with 2.25V:
Name:  DDR2-921 5-5-5-15, 225V.jpg
DDR2-969, 5-5-5-15 was accomplished with 2.35V:
Name:  DDR2-969 5-5-5-15 235V.jpg
Adding more voltage to these modules decreased stability.
I give this kit 6/10 for performance, see the conclusion for more details.
5. Conclusion:
These modules are definitely the most exotic looking things I've ever seen. I was impressed with the way OCZ implemented great looks on mid-range ram. I was really disappointed with the overclocking results; the max amount of volts I could push into this set was 2.35V with loose timings, and still was not able to achieve DDR2-1000. On the bright side, most ram running at 2.35V becomes hot to touch, but the Reaper HPC technology proved to be useful and stayed cool.
I recommend this kit to those who are somewhat in the overclocking scene and for those who love aggressive looking computer components.
Pros:
-Look fantastic!
-Lifetime warranty
-Reputable company
Cons:
-Doesn't meet an enthusiast's level of performance
-Doesn't respond well to voltage
I give the Reapers a total of 8/10!
I'd like to thank Lisa@OCZ for helping me get things sorted and for supporting me!
(Orthos test will be included in the next post)
*Sorry about the quality of the pictures. I will take better pictures when I find my camera*
-Wankerfx
Old May 28, 2007, 03:03 PM
Wankerfx's Avatar
Reserved.
Old May 28, 2007, 05:55 PM
Supergrover's Avatar
Nice Review
I would like to see those heatpipes on some nice voltage lovin DDR
Lots of bling but not alot of bang.IMO
Still nice stuff.
R.I.P.
Old May 28, 2007, 06:01 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Are you overclocking using a software program or directly through the BIOS?
Old May 28, 2007, 06:23 PM
Wankerfx's Avatar
@SKYMTL: My overclocking is done through BIOS. I don't really like using software.
@Supergrover: Thanks!
[ER]
Old May 28, 2007, 06:48 PM
Cardboard box with DSL's Avatar
Nice review!
You seem to have a knack for ram reviews!
I love the look of this ram
Old May 28, 2007, 06:51 PM
Wankerfx's Avatar
Originally Posted by Cardboard box with DSL View Post
Nice review!
Yup!
I love doing ram reviews, but will soon try to do a case review.
The ram does look amazing though!
[ER]
Old May 28, 2007, 07:09 PM
sswilson's Avatar
Nice review!
I think we're all getting spoiled with the glut of high end memory on the market right now.....
A year ago, mem which managed to do 170 above rated specs would have turned a few heads.... :)
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old May 28, 2007, 08:33 PM
Wankerfx's Avatar
Originally Posted by sswilson View Post
Nice review!
Thanks! Memory is really advanced in both visual and performance these days.
Keep the comments/questions/suggestions coming!
[ER]
Old June 3, 2007, 09:31 AM
Babrbarossa's Avatar
Just wanted to congratulate you on another great review- I haven't been around much this week so I missed it. There's alot of variation between kits it seems.
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Good Price on OCZ Reaper 4GB Kit DaBruuzer Computer & Electronics Hot Deals 5 January 11, 2008 11:15 PM
OCZ PC2-8500 Reaper HPC Review: Madshrimps Babrbarossa Reviews & Articles from the Web 2 June 3, 2007 01:49 PM
OCZ Reaper pc2-8500 $149.99 Babrbarossa Computer & Electronics Hot Deals 2 May 24, 2007 07:52 PM
OCZ PC2-9200 HPC Reaper edition 2GB kit: review by TechGage Babrbarossa Reviews & Articles from the Web 0 April 25, 2007 07:46 AM
Ideazon Reaper Mouse Gav Peripherals 1 January 11, 2007 09:05 PM
