-   Member Reviews (http://www.hardwarecanucks.com/forum/member-reviews/)
-   -   Akasa VORTEXX Neo Review (http://www.hardwarecanucks.com/forum/member-reviews/13759-akasa-vortexx-neo-review.html)
JD January 12, 2009 02:53 PM
Akasa VORTEXX Neo
Review by jdrom17
Link: Akasa
Price: $30.95USD @ Sidewinder
I decided to get this cooler for my HD4850 as the Arctic Cooling TwinTurbo no longer fits with my Crossfire configuration. For whatever reason, it's extremely difficult to find any aftermarket dual-slot solution that exhausts from the case. As far as I know, this is the only one that works with the newer cards.
It came packaged in a rather large box which had the cooler itself, 8 pieces of thermal tape for the RAM, 6 plastic washers, 4 thumb-type screws, some thermal paste and a 3pin to molex fan adapter.
Of course the fan and barbs do not come with it, I just took a picture of everything I got in the mail today :bleh:
It's a lightweight cooler with a mix of copper and aluminum. It has blue LEDs as well if your into that. The base though is rather rough so lapping it could possibly help with temperatures however since it's a stepped base I think that would be kind of hard to do without ruining proper contact.
The installation was rather simple though the semi-thumbscrews used to hold the heatsink on cannot be put tight it seems otherwise the card bends a lot. Had to basically leave them hand-tight (even though it has a cut out for a flat-head screwdriver).
One issue I have though is the MOSFETs are totally naked and the fan doesn't cover them, so this could be problematic. I haven't yet checked the temperatures on them with an IR gun though, but I might need to get some ramsinks.
Here's a before and after shot:
Unfortunately the fan uses a 3pin connector rather than plugging into the GPU itself so the GPU no longer controls the fan speed. This was something I liked with the TwinTurbo. Luckily it doesn't seem to be audible over my S-FLEX "F" fans so it's fine with me.
As it stands, I'm idling at 40C which is totally amazing IMO. That's lower than my HIS ICEQ4 card as well which idles at 55C.
1 loop of 3DMark06 with the card running at 690/1100 yielded the following temperatures:
56C on the Core/DISPIO
64C on the MEMIO
55C on the SHADERCORE
Overall a great cooler which exhausts the air out of the case. Something I wish more manufacturers would do.
1 word of advise, if your case doesn't already have vented slot covers, make sure you get at least 1 to use so that the cooler can exhaust out of the case. For whatever reason Akasa didn't include one which is disappointing.
donimo January 12, 2009 03:07 PM
stupid HIS ICEQ4 55 degree idle BS....
nice find!
JD January 13, 2009 04:26 PM
Couple more pictures of it installed:
http://i85.photobucket.com/albums/k7...x/DSC03882.jpg
http://i85.photobucket.com/albums/k7...x/DSC03890.jpg
EaGle1337 January 13, 2009 04:43 PM
anyplaces in canada have it? looks really nice too.
JD January 13, 2009 06:05 PM
Not that I know of. Sidewinder is great though, cheap shipping and no customs/duty as long as you use USPS.
EaGle1337 January 13, 2009 06:38 PM
hmm. could you take a picture of what you want to put a heatsink on?
bah it's like 58$ with shipping :(
JD January 13, 2009 07:07 PM
What the MOSFETs? The fan actually sits on top of them after further analysis and fan shroud has holes in the bottom for the sole purpose of cooling the MOSFETs. I guess just the way I was holding the card while looking at it, it appeared as though it didn't cover so I don't think I'll bother with heatsinks.
And it's only $35.71USD shipped for me (to Toronto, ON) using First Class International.
Eagle Eye January 13, 2009 07:32 PM
Looking good jdrom nice pics and great temps. You getting another for the HIS or is their heatsink good enough?
EE
JD January 14, 2009 07:35 AM
Originally Posted by Eagle Eye (Post 138315)
Looking good jdrom nice pics and great temps. You getting another for the HIS or is their heatsninks good enough?
EE
The HIS ICEQ4 is decent though it isn't as good. I think I might replace the TIM on it with MX-2 before I spend another $40 since the ICEQ4 is an extremely similar design but the fan used in it seems to have a worse noise profile.
JD January 18, 2009 09:39 AM
Well after 900s of FurMark (renamed so CCC doesn't slow it down), the MOSFETs and in general the back area of the card was only 50-60C depending on where I measured. So I think they'll be fine without heatsinks and we all know FurMark goes beyond what games do...
One note though, the backside of the PCB where the core is, that got up to 94C however that's not really this coolers fault. The core itself was at 70C.
