  #21 (permalink)
Old October 31, 2008, 05:24 AM
CMetaphor's Avatar
Quadfather
Absolutely! And thankfully there are no resolution limitations on Nvidia graphics cards. So if one day you wanted to upgrade to 3x 1680x1050 panels, you could without a problem.
  #22 (permalink)
Old October 31, 2008, 03:37 PM
Infiniti's Avatar
I was going to get three of these monitors: NCIX.com - Buy Acer X193WB Black 19IN Widescreen LCD Monitor 1440X900 2000:1 5MS VGA - ET.CX3WP.002 In Canada. But I just realized that there isn't a DVI port. Can I get a VGA-DVI adapter(3) and use it on the TH2go?
  #23 (permalink)
Old October 31, 2008, 04:31 PM
CMetaphor's Avatar
Quadfather
Absolutely! All three monitors can be connected using DVI to VGA adapters.
  #24 (permalink)
Old November 5, 2008, 12:44 AM
Aces bro, I <3 my triplehead2go.
I'll add one more con tho, not that i think any con mentioned would be a deal breaker... staring at 3 monitors for a couple hours streight is kinda hard on the eyes. i often turn two off and run in vga mode while just surfing. i wouldnt ever want to game without it tho... FSX on 3 22" monitors FTW!
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
  #25 (permalink)
Old December 2, 2008, 05:22 PM
EaGle1337's Avatar
Interesting but the games like kinda of sucky (the resolution of the textures are too low imo) either way good review.
  #26 (permalink)
Old December 2, 2008, 06:13 PM
CMetaphor's Avatar
Quadfather
What do you mean exactly?
  #27 (permalink)
Old December 2, 2008, 06:36 PM
EaGle1337's Avatar
Team Fortress 2 doesn't look right to me, the textures on like the mountains is massively stretched.
  #28 (permalink)
Old December 6, 2008, 02:42 AM
I love my TH2G. I wish I had a Digital version to support 1680x1050 monitors. I even have some picked out, although I would DEFINATLY need a bigger desk.
As for gaming, the FOV isn't actually that much bigger than standard widescreen on some games.
IE:
The Sims 2 doesn't stretch at all unless you're in the character creation screen. It then chops the head and legs off. In game you get the full experience.
FPSes are usually skewed a little.
The 2 side monitors are indeed stretched, but they seem "normal" when viewing the front monitor.
Same with Guild Wars. The side monitors are horribly stretched, but they do look normal.
Bottom line: I'd buy one. Hell, I'm thinking of buying a Digital so I can have 3x 1680x1050.
  #29 (permalink)
Old December 6, 2008, 04:14 PM
CMetaphor's Avatar
Quadfather
When the next version comes out i might be willing to sell mine deathhawk
