| Arctic Cooling TwinTurbo: Review ![]() Currently I'm using the latest BIOS I could find which happens to be from Sapphire. It has a much more aggressive fan profile than the original HD4850 BIOS and thus my temperatures using the reference cooler are lower than most but with that quite a bit of noise. With the stock reference cooler, my idle temperatures were around 60C and it was pretty much inaudible over my other case fans. When gaming, this climbed to about 75C and it was extremely audible. At times I thought there was somebody vacuuming upstairs... Installation Firstly you need to remove the reference cooler which is pretty simple, just unscrew all the screws on the backside of the card and twist the heatsink off. Next, clean up all the thermal paste on the GPU core. To clean the memory and MOSFETs, use an eraser and some isopropyl alcohol. ![]() ![]() Next attach the included memory and MOSFET heatsinks. This is where I had some issues. The first row of MOSFET sinks wouldn't fit side by side due to a capacitor or something sticking up. So thus I had to use my tin snips and cut off a bit on each side of the sink. Also one of the RAM sinks apparently hits the heatpipe so I bent it in advanced but once I got the TwinTurbo installed, I don't think I really had to but it would of been very close. I don't honestly know how long the MOSFET sinks are going to stick as they seem to have very little hold since its such a large piece of aluminum to adhere to 2 small MOSFETs. I have a feeling I'll have to do something about it eventually and I think I'd replace them with Enzotech MOS-C1s. Mounting the actual heatsink was fairly easy, pull off the adhesive backing, place the plastic spaces over the correct mounting holes, put it on the GPU and screw it in. The stock mounting setup worked perfectly without any adjustments. Plug the fan in and your done. ![]() ![]() Word of advice: This takes 2 slots easily and I'd be inclined to say 3 so that you can have some airflow. If I didn't have a bottom mounted PSU, I think Crossfire would be feasible with my motherboard at least but it would be tight. (Mind the dust )![]() ![]() As for the final temperature results, it idles at about 45C and is inaudible over my other fans from what I can tell. I'd say a 15C drop is damn good and also gaining silence. Load temps seem to be about 60C and still silent. My next plan of action is to tweak the fan profile accordingly, maybe even just run it at 100% if it's silent still.
__________________ Xeon Quad X3350 | 3.40GHz (Damn X38 chipset) ASUS Maximus Formula | BIOS RF0410 2GB Corsair Dominator | 850MHz 4-4-4-12-2T 2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T HIS ICEQ4 Turbo HD4850 @ 700/1200 X-Fi XtremeMusic Antec TruePower Quattro 850W Antec 900 [ HEATWARE ] |
Maybe it is the MB and not the case. I have ample room between my PSU and my lower crossfire PCIe slot. And what is it with dust and sound cards? ![]()
__________________ My Rig - Asus P5Q Pro : E8400 @ 3.6 GHz : Corsair Dominator 4 GB DDR2-1066 : Corsair TX 750W PSU : OCZ Vendetta 2 HS : Antec 900 : VisionTek HD4870 : Creative X-Fi Extreme Music : 1 TB Storage Internal : 320 GB External Wife's Rig - Asus P5B : E6600 2.4 Ghz : OCZ Platinum 4 GB DDR2 - 800 : Antec Tru 550W PSU : CoolMaster CM 690 : eVGA G8800 GTX : 500 GB Storage Internal : 500 GB External |
| Quote:
I guess because the Antec 900 is only a mid-tower so they couldn't make it taller. I guess it's also somewhat my motherboard's fault too since my first PCIe x16 slot is much lower than most. I have a PCI and PCIe x1 slot above mine.
Great pics and insight JD. I love the passive one that I've got on my 8800 GTS.
__________________ GA-P35-DS3L Rev. 2.0 - Intel E8400 Wolfdale @ 3.0 GHz - Thermalright Ultra 120 Extreme - 4x2 GB Mushkin XP PC2-8000 - Gigabyte 8800GTSx512 MB Arctic Cooling Accelero S1. Rev2. - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - XP Pro 64 SP2 |
I popped one onto a Sapphire 3870 and it really made a difference over the stock cooler, from 70 load down to mid 50's. And clean your sound card off will ya...lolz
__________________ GAME < Q6600 @ 3.2GHz w/ TRUE | 750i SLi FTW (pencil) | 4GB Mushkin EM2 | GTX 260 Core 216 SC | 8600GT PPU | X-Fi | 750GB | Tagan 700W | Antec 900 > HTPC < Core 2 E6600 | 4GB DDR2 | HD 3870 w/ Twin Turbo | 500GB HDD | Antec 550W Neo > |
| Quote:
Its what creative sound cards do best these days "collect dust"
__________________ The Blue Box Biostar T-Power I45 / Intel E8400 EO 1.4v @ 4.25Ghz / Sunbeam Core Contact Freezer / Muskin Ascent Redline XP2-8000 2x2Gb / EVGA GTX280 1Gb / Samsung Spinpoint F1 750Gb 32Mb x 2 / Razer Barracuda AC-1 Gaming Audio / Antec P182 / Antec TPQ 850 Watt / Windows XP MCE SP3 |
strange; my sapphire 4850 dual slot fansink version idles at 35C, and has hit 70C under intense load... idling at 35C it uses 37% fan speed. This is the version I have:
__________________ GAMING RIG: Intel E8400 45nm Wolfdale Core 2 Duo @ 3GHz 1333MHz FSB w/ OCZ Vendetta II 4GB DDR 2 800MHz (OCZ Platinum) Main: 160GB SATAII (Seagate) Storage: 500GB SATAII (WD) Radeon Sapphire HD4850 610W PC Power Silencer Asus P5Q SE |
Thanks for the review jdrom17 great to see someone take the time out to inform others. I do agree with Mr. Gruntsworthy that the temps seem high for a after maker cooler, I have the Palit 4850 Sonic 512MB which is factory overclocked and my idle is 44C and I have yet to see it go above 60C with the few benchmarks I've run so far (just go the card last night ). Maybe some thing to do with air flow in your case or the like. Just can't see this thing getting that high a temps it's huge compared to the cooler on mine and it's a Artic Cooling product.
__________________ (Antec Sonata Plus 550) (NeoPower 550) (Asus P5K-E/WiFi-AP) (E4400 2GHz @ 3GHz 9x333) (AC Freezer Pro) (4GB DDR-2 667) (Palit 4850 Sonic 512MB) (AVerMedia TV Tuner) (Seagate 500GBx2 Raid 0) (LG 20X DVD Burner) (Vista Ultimate 32bit). |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/member-reviews/10313-arctic-cooling-twinturbo-hd4850.html | ||||
| Posted By | For | Type | Date | |
| AC TWIN TURBO review - Overclockers UK Forums | This thread | Refback | October 22, 2008 12:35 PM | |
