Originally Posted by TopDogZero Hey jdrom17 I did not noticed you had the card OC'ed, for that clock the temps are good same as mine with less of a clock 685/1000 and probably less noise too, now that sounds more like a Arctic Cooling product.  |
Hehe, guess it's not totally clear in my main post. Oh well now it is.
I actually let rhdrtibl (I think that's what it's called) with 16x multisampling and full window size run while I posted that and for about 10minutes or so after and it maxed out a 60C. Wouldn't budge anymore. Apparently that's 97% GPU load by CCC.
IIRC if I crank up the fan to maximum it keeps it under 55C. Though I'd rather not deal with the noise even though its a pretty flat sound.
Originally Posted by Mr. Gruntsworthy strange; my sapphire 4850 dual slot fansink version idles at 35C, and has hit 70C under intense load... idling at 35C it uses 37% fan speed.
This is the version I have: |
In reply to this, your card is based on a totally non-reference PCB so there could be other factors that might help reduce heat.
