<~----> Eyefinity help w/ xfx r7770 - Hardware Canucks
Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old June 3, 2012, 09:51 PM
Exclamation Eyefinity help w/ xfx r7770
If you read thia i am a big fan of your youtube shows! anyways currently i have an xfx 5770 and maybe thinking of uprgading to the new xfx r7770 black edition. For the 5770 there are 2 dvi's, 1 hdmi, and 1 dp. on the r7770 thier is 1 dvi, 1 dp and 2 mdp. to setup eyefinity with the 5770 you would have to use both dvi's and the dp. how would i setup eyefinity with the r7770 for 3 monitors? would i have to use the dvi and 2 mdp or dvi and 1 dp and 1 mdp OR the dp abd 2 mdp. can you please help me? thanks. also maybe check out my channel? lol koreanPCgamer...
Old June 4, 2012, 04:30 AM
Arinoth's Avatar
Well if you want to get decent frame rates with all the eye candy on in eyefinity you're going to want to want two cards. Mainly as you will be driving 3 times as many pixels in eyefinity then in normal single monitor gaming mode, this can put a lot of strain on a single card.
Also, 3 monitor gaming is where you want to have as much video ram (memory) as possible as a lot of games use between 1.5-2GB when in eyefinity/surround. Meaning I wouldn't really recommend using an AMD 7770 to drive eyefinity if on again you want all the eye candy on. You'll probably have to settle to low to maybe mid res. Personally I'd recommend going with 79xx series cards or 670/680 in sli (or the 690) as they will be able to handle everything you can throw at it. Eyefinity/surround is typically a more expensive experience then single card gaming, and cheaping out will result in a poor experience with them.
In order for eyefinity to work, one of your three displays must be connected by/via display port, either to a display port native monitor, or using an active display port to dvi adapter. There is no other way around it, and it will not work otherwise.
Old June 4, 2012, 01:52 PM
Sorry it's single dvi single hdmi and dual mini display ports. So I would have to use the dvi and dual mdp right?
Old June 4, 2012, 02:07 PM
Arinoth's Avatar
Yes you would, however my warning still stands for driving it on a single card, especially under 1.5GB of vRAM
Old June 4, 2012, 04:13 PM
yep thank a bunch!!
Tags
3 monitors , eyefinity , r7770 , urgent , xfx
Need help with Eyefinity. Mena Troubleshooting 16 April 4, 2012 03:31 AM
Eyefinity fyshawk Display Units 10 February 23, 2011 02:53 PM
Completed SB P67 + Eyefinity writhen Case Mods, Worklog & Gallery 4 February 10, 2011 12:47 PM
Got my Eyefinity going on!!! ontariotl Video Cards 68 October 17, 2010 03:17 PM
eyefinity ... tzetsin Troubleshooting 3 May 3, 2010 08:57 AM
