-   LinusTechTips Q&A (http://www.hardwarecanucks.com/forum/linustechtips-q/)
-   -   best all rounder (http://www.hardwarecanucks.com/forum/linustechtips-q/54233-best-all-rounder.html)
mS_Design May 13, 2012 04:54 PM
best all rounder
Hi Linus,
I have been in the market for a new graphics card for a while and watched ALOT of your videos! but never bought one as theres always been newer ones just around the corner. However, being a student I cannot afford the new 600 series or 7000 series.
I first had my eye on the 570 cards as they were pretty low priced, but now I have seen that the 6970 cards benchmarks are showing are better bang for buck and are similar if not the same price. Should I A) buy a 570 as the cheapest option anyway B) buy a 6970 for just abnit more and overclock it or c) I found a 6970 "lightning" which is factory overclocked out of the box for £40 more than the "normal" 6970.
May sound a silly question for somone of your status but I have been quite skeptical as to when to buy a new card but I am starting work as a product/website/video compositor designer plus a small bit of gaming :P and just would like some honest advice!
Current rig: Q6600 processor with 4GB DDR2 Ram and 9800gt graphics! :D
Many many thanks!
Marc
dandelioneater May 14, 2012 09:48 AM
Look for a used gtx 460. they can be had for 100 bucks or less
Adzsask May 14, 2012 09:52 AM
Used 460, or 470/480 if you can, 480's are $200 new so they have to be dropping fast in price.
supaflyx3 May 14, 2012 11:40 AM
I'm not sure if you're in Canada or not, but if you are check out the BST here, 10e is currently selling a 480 for 120 + shipping, thats the same as a 470 and can be overclocked to 580 speeds if you have the cooling for it.
mS_Design May 15, 2012 10:29 AM
wow! the email notification wasnt working so well as I thought there werent any replies!
thanks a bunch guys! That helped me alot. Will get back to you if I find a good deal.
@supaflyx3 I am in uk! haha! but if the 480 can be overclocked to the speeds of the newer generation then thumbs up!
Perineum May 15, 2012 10:38 AM
I have the same setup as you and upgraded my video card. I find my CPU is now the bottleneck.... I'm currently running a GTX560Ti
