Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old May 13, 2012, 01:16 AM
Default Zotac GTX 560 TI 448 or GIGABYTE HD7850
Which one is better :
Zotac GTX 560 TI 448 or GIGABYTE HD7850 (oc to 975mhz) ?
Old May 13, 2012, 07:06 AM
Suchin283's Avatar
Definitely the HD 7850 ( OC'd to 975mhz) would be a better choice because it has the new 28nm architecture, its powerfull (compared to GTX560 TI) n stuff ( 2GB RAM and consumes less power )
Check this site out for more performance comparisons... ( Nvidia Geforce GTX 560 TI 448 vs AMD Radeon HD 7850)
GeForce GTX 560 Ti 448 vs Radeon HD 7850 – Performance Comparison Benchmarks @ Hardware Compare
Old May 13, 2012, 09:20 AM
Adzsask's Avatar
GTX 570, cheaper and better then above mentioned cards, or the dreaded GTX 480, everyone forgets him but you HAVE to still respect the power it produces(not upgrading any time soon from mine@1080P resolution)
Old May 14, 2012, 09:17 AM
I need an exact answer which is better ...
I don't need any other suggestions ...
Just tell me which one is better : Zotac GTX 560 TI 448 or GIGABYTE HD7850 (oc to 975mhz) ?
And why it is better ?
That's all I want to know .
Old May 14, 2012, 09:29 AM
stoanee's Avatar
Video Card Comparison - GPUReview.com
Here is some links.
Nvidia & Amd owners will of course prefer their own brand. Do lots of research, buy one & be happy.
heatware
Old May 14, 2012, 09:39 AM
great_big_abyss's Avatar
It's not a simple answer.
At 1920x1200 resolution the GTX560Ti 448 is faster than the 7850 in most games (including BF3).
At 2560x1600 resolution the 7850 is either faster than the 560Ti 448 or closes the gap. All settings at Ultra.
The 7850 will use almost 100 watts less under load than the GTX560Ti 448.
The 7850 sells for $260 average, while the 560Ti 448 sells for $315 average.
SO, you want pure performance, go for the GTX560Ti 448.
However, the 7850 will give you 95% of the performance for 80% of the price, while consuming less power.
For that reason, my vote is for the 7850, as it seems to be better bang for the buck. If you can find the GTX560Ti 448 for less than $280 though, then that would be the better deal.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old May 14, 2012, 09:41 AM
Agree with others. There are other factors to consider (like cost), but to answer your question simply 7850>560Ti 448core.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old May 14, 2012, 09:45 AM
Adzsask's Avatar
7850 is better yes, but after my headaches with 5870's/6970's I am done with the red team for good.
Old May 14, 2012, 10:27 AM
Thanks guys :)
Old May 14, 2012, 10:31 AM
dandelioneater's Avatar
Go for the 7850 only if you dont plan on adding a second. Stay away from crossfire.
ZOTAC announces ZOTAC GeForce GTX 680 AMP! Edition and ZOTAC GeForce GTX 680 4GB Sam_Reynolds Press Releases & Tech News 0 May 8, 2012 10:21 AM
[WTB] Zotac GTX 470 AMP! lastsplash Buy/Sell & Trade 7 February 22, 2012 09:36 AM
Zotac GTX 570 Kilauea Video Cards 10 September 23, 2011 06:13 PM
ZOTAC Announces the New ZOTAC GeForce GTX 460 AMP! Edition FiXT Press Releases & Tech News 6 August 17, 2010 08:50 PM
