Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old May 9, 2012, 12:27 PM
Question Good build or bottlenecked?
Hey guys, planning on building this new spec soon, i think i might wait for the 670, just to see how much it will be in the UK, but ill proly go fr the 680 anyway. The main game ill be playing is Guildwars 2, and although i know it wont need the best things i can find to through at it, like the 680, im building a PC to last. The spec i have so far is.
https://www.aria.co.uk/WishList/KPAGTqguBr_cXMCqm084Dg,,
How does that look? Ignore the 3 h100's lol...just 1 =p
Old May 9, 2012, 01:03 PM
Fudd Rucker's Avatar
Everything there seems to be in order, solid looking build. Dont forsee any issues with that setup myself.
I couldnt think of something snarky or interesting to put here this time around.
Old May 9, 2012, 03:50 PM
Looks good. The gtx 670 will likely give you better bang for buck once released. From what I have read so far its performance will not be much behind the 680. Whether you go for the 670 or 680 you will have a very nice setup, so in the end its your call with if the extra few FPS are worth the extra few quid.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old May 9, 2012, 03:55 PM
Apathetik's Avatar
Don't waste money on ram over 1600MHz .. there is zero real world gains in gaming. Everything else looks great though!
ASUS VE278Q 27" LED / DAS Professional Model S Cherry MX Blue Mechanical / Logitech G500 - QcK Mass / Corsair Veng 2000 / Windows 7 Ultimate 64bit
Old May 9, 2012, 06:17 PM
Default Thanks:)
Thanks guys =) Nice reply :) Never used this forum before, but that was a quick response =)
Old May 9, 2012, 06:18 PM
1600 with timings 0f 9,9,9,25 or better
and just a suggestion, if you do go corsair go HX or AX, not TX or CX, 750 is ample by all means, however, voltage regulation and such is quite a bit better on the HX and AX. Or you could also opt for something from the seasonic, XFX and such power supplies, there is plenty of good, not to expensive power supplies out there without having to sink to a "mid grade" the rest of your parts are top notch, why not go something a little better in the power supply department(at least higher on the totem pole?)
Old May 9, 2012, 06:41 PM
Thanks guys =)
Old May 15, 2012, 09:34 AM
Beter take something that supports SLI becouse MSI Z77A-G45 does not ?
If you decide in near future that you want another card :)
I would anyway, your choice.
Old June 1, 2012, 10:12 PM
fishingfanatic's Avatar
Smile Good Build
As another member said, go modular for your psu, easier to work with, better air flow through the case as well.
Swap the SSD for a Vertex,love Mushkin ram though, so I would recommend those or G Skills. Don't know about now, but I found Corsair ram to be a bit pricier than most. As long as they're lifetime
warranty though, whatever you like.
Enjoy the build and resulting system!!! Should keep you smiling for a while.
Old June 2, 2012, 11:42 PM
Not checked all the parts but scan.co.uk has that 670 for £20 less.. though some other parts are 1 or 2 £ more.. Worth looking at scans bundles too though..
Tags
custom gaming pc
Gtx 690 and my old tower; bottlenecked? elimtl Video Cards 12 May 2, 2012 07:13 AM
is this build good? neo678123 New Builds 3 January 22, 2012 06:11 PM
dual 5850 bottlenecked by x6 1055t? Cazushio Video Cards 1 November 2, 2011 05:09 AM
what type of setting will my budget pc play and will this be bottlenecked by antyhing mrperfect1995 New Builds 2 November 1, 2011 10:49 PM
9800GTX from EVGA get bottlenecked by my CPU? C_O_N Video Cards 26 April 16, 2009 11:26 PM
