Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old April 30, 2012, 07:43 PM
Default Cable Sleeving Question
I want to sleeve my cables and I was just wondering what size cable sleeves I need. I am going to sleeve each wire individually and I am going to buy dazmod's darkside sleeves. Also what size heatshrink would I need?? Thanks for Reading!
Old September 12, 2012, 06:08 AM
1/16" will be little tight & 1/8" will be little loose it is on you .
Old September 12, 2012, 06:34 AM
AmuseMe's Avatar
Could always look at MDPC-X sleeve too ;)
DEAD CA$H
Old September 12, 2012, 06:59 AM
Pabz0r545's Avatar
All your sleeving answers should be able to be solved here:
Sleeving Discussion & Gallery thread
"Water cooling is basically like injecting drugs into your veins and you'll find that what once was enough is quickly not enough anymore."
-Linus
Old September 12, 2012, 01:34 PM
lowfat's Avatar
Fixed your link.
Tags
cables , darkside , dazmod , powersupply , sleeving
cable sleeving kit QuickDeath Case Mods, Worklog & Gallery 10 February 11, 2012 07:08 PM
cable sleeving, can I buy it from a department store? quikgp Cases 7 May 13, 2009 09:44 AM
Cable sleeving, what a nightmare... Liu Kang Guides & How-to's 10 April 21, 2009 01:50 PM
Cable sleeving in toronto? elninio CPU's and Motherboards 14 June 5, 2008 06:05 AM
Sata Data Cable Sleeving ChuckleBrother Storage 7 April 11, 2008 06:32 PM
