Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old April 29, 2012, 05:26 PM
Default Air Cooling, CPU
What is a very good Air Cooling system for an i7 CPU?
Old April 30, 2012, 02:56 PM
Depends on which i7? Are we talking 1366, 1155, or 2011?
Are you wanting to overclock or are you looking for a replacement that is quieter and performs much better at stock clocks?
What case are you using? I need to know the clearance you'll have.
What's your price range? Are you looking at something around $20, $50, $75?
Do you want something with an interchangeable fan?
Do you want something that comes with an LED fan?
If so, what color?
Alternatively, are you trying to match a specific color scheme?
Need to know the basics before I can recommend anything solid.
Old April 30, 2012, 03:02 PM
botat29's Avatar
I will really like to get my hand on a Phantek, they are made by the same OEM manufacturer who build the Noctua, you can from the video that many parts look exactly the same, especially the mounting kits and their bags. The backplate is the same one Noctua use.
Newegg.ca - Phanteks PH-TC14PE_RD 140mm UFB (Updraft Floating Balance) CPU Cooler
Old April 30, 2012, 03:03 PM
Adzsask's Avatar
^ +1 to tis, my i7 950 is way way hotter then a 2600K at the same frequency, as it should be my processor is 130 watts, a 2600K is 95 watts.
Old April 30, 2012, 06:59 PM
grinder's Avatar
that cooler is a beast!!!! i like noctura after market coolers too
I7 860 Cooling and GPU MarkOne New Builds 42 December 26, 2009 08:33 AM
Arctic Cooling Accelero TWIN TURBO Pro Cooling for GPUs FiXT Press Releases & Tech News 6 November 16, 2009 12:51 PM
i7 rig needs cooling kaufman37 Water Cooling 9 October 19, 2009 09:10 PM
Passive cooling/silent cooling Cowboy Air Cooling 9 September 17, 2009 11:38 AM
Cooling SLi? DSNB Troubleshooting 14 January 24, 2008 01:06 AM
