Originally Posted by CouchSloth Coarsair 600 would not work with H100. I have the same case and had bought the cooler. The cooler gets in the way of the VRM and memory slots on an ATX board. In the end I fitted the radiator inside the case and the fans on the outside. They are a little thick for the top mesh filter, but the filter does close down. If you find a case that can support the H100 (enough height at the top of the case) then it should handle everything else. |
This YouTube vid seem to differ:
Building a system with the Graphite Series 600T Silver Edition and Dominator Platinum memory - YouTube (straight from Corsair), and this one
Building a New Gaming PC with the Corsair Carbide Series 400R Mid-Tower Case - YouTube
Unless you are saying that you have the ASUS Sabertooth, and that it has problems fitting.
