Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old April 13, 2012, 07:05 PM
Default Choosing a PC case
I need suggestions for a new full tower case!
Must have:
1) Great airflow
2) Dust filters
3) Good cable management options
4) Water cooling compatibility
5) Room for a at least 240mm radiator
6) Good space to host a large sized GPU
Optional:
1) Fan controls (would be good)
2) Side window
3) Hot swaps for SSD and 3.5 bays
4) LED's :D
Also, my budget is around $150 (can go over but prefer not to)
Thank you already :)
Old April 13, 2012, 07:17 PM
sswilson's Avatar
Sounds like a LVL 10 GT to me, although that's gonna be more than $150..... :)
Gigabyte Z97N-WIFI / i7 4770K / 2X 8G Gskill 1866 Sniper / XFX XTR 750 / EVGA GTX 970 SSC ACX 2.0+
AZZA Titan 240 / Custom WC / Intel 730 Series 480GB SSD / Seagate Barracuda 1TB / Dell UltraSharp U2412M
Old April 13, 2012, 07:20 PM
I looked it up and its wayy over budget.. and it looks weird :D
Old April 13, 2012, 07:23 PM
supaflyx3's Avatar
shinobi XL.
Old April 13, 2012, 07:40 PM
stoanee's Avatar
Coolermaster Storm Trooper can be PM'd below $150
heatware
Old April 13, 2012, 07:53 PM
sswilson's Avatar
Might be best if you let folks know what your current "no budget concerns at all" choice would be and they can probably point you towards something similar.
Old April 13, 2012, 08:09 PM
I looked into the Stor Trooper and I just dont think i will ever grow to its looks :D
Nd did mention that my budget is around $150 but I would prefer not to go over it
Also, any opinions towards the NZXT Phantom?
Old April 13, 2012, 08:29 PM
chubaka's Avatar
600t..
Old April 13, 2012, 09:03 PM
Pabz0r545's Avatar
Switch 810 or Antec 1100?
Not sure how close to 150 they are but I think close.
Old April 14, 2012, 06:08 AM
The 600t and 1100 are mid towers...
And the 810 is way over as well
Need help choosing full tower case only steve.gt New Builds 28 May 13, 2012 12:55 PM
Need help choosing please! stu_uk30 Video Cards 3 April 14, 2011 04:36 PM
Choosing a new case Hexofire Cases 7 August 7, 2010 07:55 AM
Need help choosing a cheap case NoobLordSpud New Builds 5 November 26, 2008 10:04 AM
Help choosing a 24 LCD jin15 Display Units 8 August 17, 2008 10:28 PM
