Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old April 14, 2012, 08:04 AM
Bond007's Avatar
Sounds like you want to have the perfect case and not pay for it. The above recommendations are about as cheap as you are going to get and meet all your criteria. You either going to have to cut some needs or increase your budget IMO.
Desktop: Arc Midi R2, Z77-D3H, 3570K 1.09v/4.1ghz with Zalman Optima Cooler, Corsair Vengeance [email protected], XFX R9 280X DD, Bitfenix Fury 750w, WD Black 1TB, Intel 530 120GB
Old April 14, 2012, 10:52 AM
Pabz0r545's Avatar
Very true.
To the OP, the antec 1100 is a "super mid tower" which has the same amount of expansion slots as a full tower has. So pretty much it's a full tower. I have no clue why they chose to name it this way.
And the NZXT Switch 810 is only 20 dollars more then your said budget, which can supposedly be gone over. I don't see how that is way over.
The switch 810 is definitely as close as you will come to those listed features and price.
Old April 14, 2012, 02:32 PM
XNine's Avatar
Manufacturer Rep
OP, I'm not sure where you are. Your profile says London. If you're in London, Ontario, you can see that the Switch 810 is priced reasonably:
NZXT Switch 810 Full ATX Steel Case 4X5.25 6X3.5 2XUSB3.0 Audio and Mic Input - Black - NZXT - CA-SW810-B1
Canada Computers | Cases | NZXT SWITCH 810 Full Tower Chassis WHITE
If you're in London, England
http://www.amazon.co.uk/s/ref=nb_sb_...ch+810&x=0&y=0
If you don't particularly like the case itself, well, you're going to be hard pressed to find all of the features you listed without paying over 200 bucks. Plain and simple.
CaseLabs Media Machinist
Old April 14, 2012, 05:07 PM
Slik's Avatar
Originally Posted by DaawiS View Post
I looked it up and its wayy over budget.. and it looks weird :D
I don't think it looks weird at all. One thing for sure,for cooling and the amount of room in that case for any future upgrades,the Level 10 GT will be the one and only case you will need for a long long time. You can put ANYTHING in that beast. It's not much over your budget,and damn well worth the miimal exta cost. Step out and BUY it. You won't be sorry.
In Win H Tower -i7 4930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 Titan X SLI - Xonar Phoebus Sound Card- LG 34" Monitor-Razer Tiamat Headphones-Butt Kicker Gamer-TrackIR 5
Old April 14, 2012, 06:46 PM
MARSTG's Avatar
HAF 932? Full tower, even takes E-ATX mobos, you can put a 2P or 4P system. The only thing that it doesn't have is the hot swap. But why would you need that anyway? the hot swap was invented for servers, to avoid the downtime. you really need that option? 145$ on newegg.ca
Old April 15, 2012, 06:11 PM
What about the HAF X, a little over your budget, but not much.
Old April 29, 2012, 08:04 AM
Thank you for all the answers! Ive narrowed everything down and its either Antec 1100, Haf 932 and possibly CM 690ii White... Anyy suggestions between those three?? I do plan to watercool later on (nothing big) so which one would be the best for that?
Need help choosing full tower case only steve.gt New Builds 28 May 13, 2012 12:55 PM
Need help choosing please! stu_uk30 Video Cards 3 April 14, 2011 04:36 PM
Choosing a new case Hexofire Cases 7 August 7, 2010 07:55 AM
Need help choosing a cheap case NoobLordSpud New Builds 5 November 26, 2008 10:04 AM
Help choosing a 24 LCD jin15 Display Units 8 August 17, 2008 10:28 PM
