-   LinusTechTips Q&A (http://www.hardwarecanucks.com/forum/linustechtips-q/)
-   -   Dual GPU or SLI (http://www.hardwarecanucks.com/forum/linustechtips-q/53333-dual-gpu-sli.html)
Strikerm4 April 13, 2012 02:22 PM
Dual GPU or SLI
Which is better or will give better performance? Dual GPU cards or SLI with two seperate GPU'S
supaflyx3 April 13, 2012 03:16 PM
SLI with two separate cards, dual GPU cards are usually downclocked to keep within a power TDP envelop.
Razamatraz April 14, 2012 03:37 AM
That's true but the price is usually far better on the dual gpu card.
Eg GTX 590 $700
2* GTX 580 $900 - $1000
2 580s were a bit faster but not by a lot. to get the same price it'd be 2 570s which were not faster.
I also wonder, given the reduced power consumption of the 680 if they might be able to dual it and still fit that within two 8 pin connectors with no downclocking this time.
Pabz0r545 April 14, 2012 10:46 AM
Isn't a 590 essentially 2 570's?
MARSTG April 14, 2012 06:58 PM
no, is 2 x 580 downclocked chips. Downclocking is done because of the constraints of operating under simple air cooling and taking only 2 slots. Fancier solutions (the triple slot Asus MARS II) or water cooled blocks can take care of that and simply overclock the chips. Power intake has never been a problem for any card : if you need a more powerful PSU you will have thought of that before getting the videocard.
Arinoth April 15, 2012 04:24 AM
Exactly what Supa said
