-   LinusTechTips Q&A (http://www.hardwarecanucks.com/forum/linustechtips-q/)
-   -   GA-990XA-UD3 sata speed with ssd is slow?! (http://www.hardwarecanucks.com/forum/linustechtips-q/53002-ga-990xa-ud3-sata-speed-ssd-slow.html)
DoocMoStar April 3, 2012 02:28 PM
1 Attachment(s)
hi i have a question for you guys ... if that is normal?! ty all
EmptyMellon April 3, 2012 08:43 PM
Those number are only good for a previous gen SSD - SATA II, 3Gb/s, which yours is not.
1. Have you installed your Windows 7 Pro from scratch or did you restore it from an image/back-up? Should do a clean install if you have not done so.
2. Have you enabled AHCI, in the BIOS? Your mobo might be defaulting to "Native IDE", need to change that to "AHCI"
If you don't know, check your motherboard's manual, Sec. 2-6, page 45; if you don't have a manual, you can download/save it from: http://download.gigabyte.us/FileList...90xa-ud3_e.pdf
[FYI, in the future, don't be afraid to create a thread in the appropriate section (i.e. Storage or Troubleshooting), for better visibility and quicker response by fellow members.]
DoocMoStar April 4, 2012 05:16 PM
I have try all
Hi have try all dont work.!!!! Help plz!
MARSTG April 5, 2012 05:50 AM
is it a boot drive or you just try it as a secondary drive? try switching the sata port
EmptyMellon April 5, 2012 03:10 PM
Try using ATTO and/or Crystal Disk Mark 3
Two things:
1. Can you check in your BIOS that your SATA3 is "Enabled" - same section and page
OnChip SATA3.0 Support
Enables or disables the SATA 6Gb/s function integrated in the Chipset. When set to Disabled, the SATA controller will operate in SATA 3Gb/s mode. (Default: Enabled)
2. Could you run additional SSD tests using ATTO or Crystal Disk Mark 3, and see if they give you the same results? [Edit: You are using AS SSD to do the test, and that is a punishing software; I am sure you will see better numbers using ATTO and/or Crystal Disk Mark.]
costaeder November 25, 2012 05:50 PM
Hi all!
I have the some problem!
- Chip Sata Type = AHCI
- On Chip Sata 3.0 Support = Enabled
- Partition aligned
- AMD Sata Drivers 9xx Installed (latest version)
- MB Bios F9 Updated
- Corsair Force 3 Firmware 5 updated.
- Black Sata 6gb Cable installed
- Trim Enabled
- Reg Msahci 0
Seq
Read 197
Write 85
512k
Read 188
Write 80
4k
Read 16
Write 62
4k qd32
Read 96
Write 84
What can be happening here? Help!
RazREdgE December 5, 2012 05:11 PM
http://i50.tinypic.com/2lsgowl.jpg
Not sure why your having so much trouble. I'm running the same board with a Vertex 4.
