-   LinusTechTips Q&A (http://www.hardwarecanucks.com/forum/linustechtips-q/)
-   -   Linus unbox raven rv03! (http://www.hardwarecanucks.com/forum/linustechtips-q/52706-linus-unbox-raven-rv03.html)
bostonstapler March 24, 2012 08:37 PM
Linus!!
Can you please unbox the silverstone raven rv03 !? Hopefully i can upgrade from horrible thermaltake v3!
Thanks!
supaflyx3 March 24, 2012 09:15 PM
Silverstone Raven RV03 Product Review - YouTube
/facepalm.
bostonstapler March 24, 2012 09:17 PM
tis not linus! ....... : (
supaflyx3 March 24, 2012 09:23 PM
Why does it matter if its Linus or not...? Linus unboxes things, that is a product review. I really hope you don't base your product purchases on linus's videos.
headsh0t March 24, 2012 09:32 PM
Is this Lysenberg's new account?
bostonstapler March 24, 2012 11:11 PM
Because its his uncommon comments that you dont hear from reviewers that he says about products. Reviewers will say all the BOX specs, Linus will say all the specs and say what he thinks of them. Example : he usually checks the rigidity of side panels, or says that these plastic prongs from the top panel or side panel look cheap and then says to be careful with them. He will say outloud what he thinks of features when he tries them out on the spot and that is what im looking for. Uncommon comments that no one else will say and that will tell me if the raven rv03 has certain features that lack attention to detail or just simply if it rocks!
headsh0t March 24, 2012 11:23 PM
Most reviewers do give their opinion of product and give you pros and cons, unless you watch 3D Game Man reviews. That's what a review is.
Linus March 24, 2012 11:55 PM
Silverstone chassis are hard for me to come by, but I can assure you that a HWC review is as good or better than anything I can create :)
bostonstapler March 25, 2012 10:29 AM
Fine, i tried ! Thanks anyway. : )
Adzsask March 25, 2012 10:42 AM
Hi lysenberg , didn't you get banned ??? no one makes these threads other then one person, lysenberg...
