Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old February 18, 2012, 08:07 PM
Default Core i7 2600k VS 2700k
I want to know the differences between those 2 processors in real world 2700k is better than 2600k ??
is it worth getting 2700k isntead of 2600k for a mid gaming pc?
is it worth pay the extra 50 or 80 bucks more?
Old February 18, 2012, 08:10 PM
nope not even worth it
even in overclocking situation
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old February 18, 2012, 09:13 PM
Silent_Avenger's Avatar
Agreed the 2700k isn't worth the extra money not even if you are going to keep the chips stock. Save the money and put it towards a better SSD or something.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old February 18, 2012, 09:26 PM
There is no physical difference in the two processors, there is a logical difference where the 2700k comes with a stock multiplier of 35 instead of the 2600k's 34. With both being unlocked 'k' processors you can simply go into your bios on a p67 or z68 motherboard and increase a 2600k's multiplier to match a 2700k.
In terms of overclocking the 2700ks aren't 'binned' or higher caliber than the 2600ks, it's still luck of the batch and you can get golden 2600k/2700ks and you can get poor 2600ks/2700ks.
So I would conclude that there is no difference between the two processors other than intel re-branding some 2600ks as something 'new' and 'faster'.
Old February 19, 2012, 07:08 AM
100mhz different. Buy a 2600k and overclock it by 100mhz (one multiplier) and they are the same. Don't go with the 2700k unless its within a couple dollars of the 2600k.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old February 19, 2012, 09:37 AM
its pointless, there may be a very very fine difference in binning as in the 2700k has a slightly better stepping and reduced voltages for its stock clock rate, but for the price difference, you can get a 2600k with an aftermarket cooler and overclock it to equal or massively exceed the 2700k and still walk away saving $. It is marketing, some folks see the number 2700k and the slight clock speed boost and they are willing to pay the extra what $30-$50, but in the real world, the difference is so small, its not worth it. There is a very small amount of binning though, as if knowledge serves me, the 2700k runs a higher multi/clock speed and uses the same power as 2600k, so, in the real world, it matter nothing, both using the same stepping now, both are pretty much able to hit the same overclocking ceiling, so you basically are paying an extra $20 or so for an extra 100Mhz, which in my opinion is silly.
Old February 20, 2012, 05:34 PM
ok thx for all the info on these 2 procesors now I know what to do thx
Old February 22, 2012, 10:32 PM
At some stores the 2700k is cheaper though.
Old February 22, 2012, 11:18 PM
While that may be true at some retailers if you do some shopping around or use a site like shopbot.ca the 2700k's lowest price is rarely lower than the 2600k's lowest price.
Old February 23, 2012, 01:24 PM
Let us know what you end up getting and what you get it to. I don't have a 2600K yet but I do have the 2500K and 2700K and love them both. Very good performers! Sometimes I notice differences other times I don't (came from i7 920 and i7 950)
Comp1 (Mine) : ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
Intel core i7 2600 vs 2600k James Bond 007 CPU's and Motherboards 5 December 21, 2011 09:19 PM
Intel Sandy Bridge Core i5-2500K & Core i7-2600K Processors Review Comment Thread SKYMTL CPU's and Motherboards 52 November 6, 2011 08:21 AM
Intel Core i7-2600K with GIGABYTE Z68X-UD7,the latest High End Platform OC Guide windwithme CPU's and Motherboards 6 July 14, 2011 09:46 AM
Having Core i5 NON K Hould I buy a 2500K or a 2600K hellire666 CPU's and Motherboards 10 May 16, 2011 04:23 PM
