Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old February 5, 2012, 12:11 PM
Default ocz vertex 3 max iops score
i would like to know what to do to get the full power of the ssd ocz vertex 3 max iops(120gb).
Old February 5, 2012, 02:25 PM
gingerbee's Avatar
make sure it's offset is right and if using windows 7 fresh install you will be fine if cloning make sure you use the new acronis it keeps the offset right so you get max read and write that's all
Old February 5, 2012, 02:48 PM
pellelu's Avatar
I don't think you need to care about the offset with Win 7... As long the SSD is raw, Win 7 takes care of it.
Difference between OCZ VERTEX 3 MAX IOPS and OCZ VERTEX 3 Fro Storage 2 October 15, 2011 03:54 PM
SSD Firmware 2.13 for OCZ Vertex 3, Vertex 3 Max IOPS, Agility 3, Solid 3, RevoDrive onethreehill Storage 0 September 21, 2011 09:32 PM
OCZ Vertex 3 Max IOPS 240GB SSD Review Comment Thread SKYMTL Storage 11 July 7, 2011 03:21 PM
OCZ Technology Announces Vertex 3 Max IOPS Solid State Drives FiXT Press Releases & Tech News 9 May 4, 2011 07:37 AM
