Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old January 20, 2012, 02:19 PM
Default What do you think of my current setup?
Hello! I was wondering by today's standards what you think of my rig. AS far as computer gaming goes, im humble and poor, so its not very spectacular at all.
Im running:
AMD Phenom 9150e 1.8 ghz Quad core
EVGA GTS 450 superclocked to 882 mhz
4 GB of DDR2 SDRAM
Gateway RS780 running an AMD 780 chipset
550 Watt Ultra LSP PSU
640 GB Western digital HDD
Case is a mid-tower with, as far as i can see, 1 120mm fan (maybe even an 80 mm). I believe this to be a bigger problem then alot of the components.
If i were to upgrade to a new rig that was at a decent price, id try for:
Intel i5 2500k
Radeon 6870
8 Gb DDR3
1 TB HDD
Full tower case with 2-3 120mm fans
650 Watt Corsair
Probably a gigabyte LGA 1155 mobo with support for DDR3 and SLI/crossfire.
Old January 20, 2012, 02:28 PM
CMetaphor's Avatar
Quadfather
Why a new Rig? What resolution are you gaming at? The only real problem with your system is the processor IMO. Check the motherboards support page for BIOS update that support newer processors, and get one of the nice ones that is compatible (preferably black edition). Then just grab a good CPU cooler and overclock the hell of out it. You'll be surprised how much better your gaming experience is at 3.5Ghz or higher than it is as 1.8Ghz.
Old January 20, 2012, 02:31 PM
dandelioneater's Avatar
Ugrading from that phenom cpu to the 2500k would be a great upgrade. If you could muster up enough cash maybe try to get a 6950 card, or wait for a midrange 7xxx series gfx card. In the meantime you could try overclocking that phenom a bit to get some further life out of it. But graphics cards aside, the 2500K is the chip to get for a gaming build hands down. If money is really tight like you seem to say, a bios update and a black edition chip would be great too and alot cheaper as CMMetphor says.
Old January 20, 2012, 02:34 PM
CMetaphor's Avatar
Quadfather
Or, if you want to save money and not go the fanboi route, you may be able to drop a Ph2 X6 1090T/1055T in that motherboard and still be within 10% the performance of an i5 that uses the same video card (which can always upgrade as well, in the same motherboard) .... without having to change your whole dang computer to do it.
Old January 20, 2012, 02:46 PM
I game at 1440x900 as its the native res of my monitor. But, like i said, i have no money to spare atm and so im trying everything to keep the card running below 70 degrees C so it lasts longer.
I thought the processor was in need of upgrade as well. But i havent read up too much on the difference in performance of a socket AM3 CPU running in AM2+. How much of a difference will i see?
Old January 20, 2012, 02:52 PM
CMetaphor's Avatar
Quadfather
At that resolution a crazy video card upgrade wont really help that much. The processor should definitely be your focus. If you're that pressed for cash, then your first choice should be looking here on the forums for a Good quality used Heatsink/cooler thats in decent condition. Im sure if you can scrounge together 30-40 bucks it'll be enough for something decent. With that the temps will drop drastically on your current CPU, so you can overclock it more AND you'll be able to use the same cooler on whatever the next processor is (providing its compatible, socket-wise). How much money can you realistically put together to help your gaming experience?
Old January 20, 2012, 02:57 PM
150 or 200 max currently.
Old January 20, 2012, 03:00 PM
CMetaphor's Avatar
Quadfather
Whoa!
You sir, could be looking a nice upgrade sooner than you think!
Need to have a few questions answered now:
1- What is the exact model of the Gateway PC you're running right now?
2- What is the vertical clearance from the CPU socket, approximately? (Height between the CPU and the case's side panel)
3- Are you willing to buy use from trustworthy members here on HWC?
Old January 20, 2012, 03:10 PM
Originally Posted by CMetaphor View Post
Whoa!
1: DX-2400-09
2: roughly 6-7 inches
3:not exactly
Also, i really would need to stick to my budget of 200 at the very max
Old January 20, 2012, 03:27 PM
CMetaphor's Avatar
Quadfather
1: DX-2400-09
3:not exactly
1 -Can you double check that model #? I couldnt find and DX2400 on Gateways site, but I did find this on the HP site: HP Compaq dx2400 Microtower PC*-* Download drivers and software - HP Business Support Center - BUT that seems to be an Intel-based system, not AMD like you've stated.
2- That should be plenty for a decent mini tower cooler (like a CM TX3) or a decent to high-end top-down cooler. We'll see how much money is left over after we determine what your motherboard can take, processor-wise.
Current Draw Reyzac Power Supplies 17 October 23, 2010 09:04 AM
AM3 current and future matsta31 CPU's and Motherboards 29 January 10, 2010 08:26 AM
My (current) open bench setup Cowboy Case Mods, Worklog & Gallery 9 July 16, 2009 05:58 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
lol @ my current pc Kayen Case Mods, Worklog & Gallery 12 July 25, 2008 01:26 PM
