Water cooling - What parts are required? This is a question from Xeonsteel08: Quote:
1. A case that is water cooling friendly. So far the only one that REALLY gets my 100% unreserved recommendation is the 800D from Corsair 2. LOTS of patience. A slow, careful water cooling build is NOT going to leak. A rushed/excited one WILL. 3. CPU block, GPU blocks (full cover recommended), pump, reservoir, tubing, coolant (distilled water recommended with Primoflex LRT tubing. Then you don't need any additives), fittings/clamps |
Linus, you forgot the radiator(s) and fans. And the OP mentions GTX580 Hydro's so he won't need GPU blocks as those cards come with blocks. I haven't had the chance to play with a Level 10 GT yet, but rumor is that you can fit a triple rad internally up top, and a double rad vertically beside the drive cages. The SB chips don't seem to run super hot, so a triple may be able to cool the CPU and both GPU's at their max overclock. |
Yeah i agree sugar (i don't mean you're my sugar but you got the point :D) and getting a Watercoolign case will help you getting more fans more radiators and of course OC to the max For any info go to NCIX PC on facebook.It's the official NCIX's page for answering questions and getting answers so fast!! |
| All times are GMT -7. The time now is 10:33 PM. |
