Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old October 6, 2011, 11:00 AM
Linus's Avatar
Default Will my GTX 560 Ti SLI setup benefit from a dedicated PhysX card?
This is a question from hadin101:
Hello there! I've been trying to do some research but i really havent been able to find any real answers to if a dedicated physx card would improve the performance of my 560 ti sli set up. Ive read maybe one post on a forum saying that with my set up i really wouldnt benefit from a dedicated physx. I was thinking maybe a gts450 or a gtx460 not really sure what would be best or if there is another card that would be better suited for my set up. Any advice would be greatly appreciated :)
It depends on the games you play more than anything else, but for most games your GTX 560 Ti setup should have enough horsepower left over to run PhysX calculations on one of the cards. If you really find it getting bogged down (and turning PhysX off helps) then a 460 or something might not be a bad addition.
Personally I think it's usually more sensible to upgrade the overall graphics platform rather than just throwing more cards at the problem though.
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
Old October 6, 2011, 11:10 AM
Arinoth's Avatar
I have personally tried this and found minimal to no added benefit other then running my 560 Tis hotter. I tested it with several Phsx games using a GTX 550 Ti as the phsyx card.
Old October 6, 2011, 06:34 PM
Trial Member
Well thanks for the advice i really appreciate it. I will save the money for future graphics card upgrades hopefully ill get my hands on a 590 this holiday season!
Dedicated Physx Card Difference in Alice Madness Returns ineedaname Video Cards 13 July 23, 2011 04:08 AM
GTX 580+GTX 275 Dedicated PhysX Rocyaic Video Cards 6 June 15, 2011 11:13 PM
Question regarding real world value of dedicated PhysX card Perineum Video Cards 7 May 10, 2011 06:43 PM
Dedicated Physx card with main ATI card? NineLives Video Cards 5 June 27, 2010 07:20 PM
Dedicated physX GPU MarkOne Video Cards 1 January 18, 2010 04:27 PM
